- Q.Is it acceptable to
terminate EIFS at grade? I’m worried that this
might provide easy access for termites, or might allow
moisture to wick into the wall.
A.Architect and
EIFS specialist Richard Piper responds: EIFS
should be terminated above grade for the two
concerns you mention — termites, and the
possibility of moisture entering the wall by
capillary action. Snow and ice can also cause water
to back up into the wall in winter. Most building
codes require the top of the foundation to be 6 or
8 inches above grade for the same reasons. If you
want the color and texture of the EIFS finish to
extend to grade, the exposed portion of the
foundation can be skim-coated with EIFS base
material and finish.
Ideally, the lower edge of the EIFS extends
approximately one inch below the top of the
foundation and is sealed to the foundation to
prevent air infiltration. If the resulting thermal
gap is your primary concern, it is better to
address it from the inside, even though interior
insulation is generally not as effective as
exterior insulation. The possible damage by
moisture and termites outweighs, in my opinion, any
advantage of continuous exterior thermal
insulation.
