Just about all my trim details could be described as
old-fashioned; I like to build new houses with the traditional
look and feel of homes built a century ago. I still cope
molding joints rather than resort to corner blocks, and I still
build railings with balusters and handrails rather than using
drywalled cripple walls with wood caps. I don't take shortcuts
when it comes to trimming the windows, either: Instead of
picture-framing the units, I always build stools with aprons
underneath and fitted window casings.
Years ago, when I was trimming apartments, I could make a
window stool and install it with casings and an apron in less
than 30 minutes. Today I spend several hours to trim out a
single window using the method described in this article. I
consider it time well-spent, however, because nearly everyone
notices how attractive my windows are. I've even gotten a
couple of new homes to build because of my window
detailing.
Even though I own a high-end custom residential construction
company, at heart I'm basically a trim carpenter. This approach
— careful detailing of traditional trim — reflects
my passion for fine interior millwork and has been responsible,
in part, for our success in the lucrative custom-home
market.
The Look Starts With the
Stool
The window stool is critical to giving new windows the
character of homes built 100 years ago, so that's where I focus
much of my attention. Instead of 3/4-inch stock, I always use
material of at least one inch thick, which better matches the
standard stools of that era. I typically use 5/4 poplar for
paint-grade work, choosing the flattest, straightest lumber I
can find. I clean up both faces with my planer and belt sander
while leaving as much thickness as possible — preferably
more than an inch.
I also think that a traditional-style stool should have a
routed cove-and-bead profile that faces down, with the top edge
simply rounded over (see Figure 1). That seems to best match
the stool profiles I've seen in photos and old millwork
catalogues. While the exact underside profile isn't critical, I
generally use a 5/16-inch roundover bit to profile the upper
edge. A smaller bit doesn't take enough off, and a larger bit
can interfere with the underside profile, particularly when
you're using thinner stock. Before routing the stool, I
carefully check that the edge of the stock the bearing rides on
is defect-free, since any small void or irregularity will be
transferred to the profile.
Figure 1.For the look of a traditional stool, the
author uses full 1-inch-thick stock profiled with a router. He
shapes the bottom edge with a cove-and-bead bit and the top
edge with a 5/16-inch roundover bit. On the bottom photo, the
finished edge profile with the router and trimmer held in
place.
To determine the stool's length, I measure between the inside
faces of the window jambs and add 3 inches to allow for stool
overhangs, jamb reveals, and casing reveals, plus twice the
width of the casing trim.
For the apron style that I use here, the stool must be wide
enough to leave 2 1/2-inch-wide ears after it's notched around
the drywall. I start the cuts for the ears with my table saw,
then finish them with a jigsaw (Figure 2).
Figure
2. It helps to have the right
tools: The author uses a table saw to cut the ears on the stool
(top) and a jointer to taper the extensions so they match the
plane of the drywall next to the window (middle). A Kreg
machine makes quick work of boring pocket holes
(bottom).
Install the Jamb Extensions And Stool as a Unit
Before installing the stool, I first cut and assemble the jamb
extensions from 3/4-inch stock. I carefully measure from the
outer edge of the window jamb to the surface of the finish
drywall at the window's four corners, then do a quick drawing
of the required jamb extensions. Unless you are living in a
perfect world, these widths will vary slightly, and so should
your jamb extensions.
I take the time to taper the jamb extensions with my jointer to
the correct width for each corner, though this same taper could
also be cut with a power planer or even a block plane. I also
back cut the extensions with a 2-degree bevel on their face,
with the high point on the inner edge (a good reason to use a
jointer). This extra step helps me get precise mitered casing
joints, because it allows the miters (which I also back cut) to
lie flat against the wall even if the jamb extensions extend
slightly past the wall plane.
When working with larger windows, I like to install the jamb
extensions and stool together as a unit. First I fasten the
jamb extensions together at the top butt joints with pocket
screws, and then I pocket-screw the side extension jambs to the
stool (Figure 3). The pocket screws offer a very strong, tight
connection without requiring glue, allowing me to shim and
install the whole assembly at one time. On smaller windows with
shorter stool stock, where extra joint strength isn't
necessary, it's okay to simply use pins or staples to fasten
the extensions together and the stool to the extensions from
underneath.
Figure 3.Pocket screws hold the jamb extensions
together so they can be installed as a unit (top). On large
windows the author attaches the stool with screws (bottom); on
small ones he pins the stool to the side jambs from
beneath.
I size the jamb extensions to leave a 1/4-inch reveal where the
extension meets the window jamb. On casement units, I like to
leave a larger 1/2- to 3/4-inch reveal along the bottom of the
window above the stool, so the crank can turn freely.
After setting the jamb extension and stool assembly in place
against the window, I center and shim the stool to have an even
reveal along the bottom of the window (Figure 4). For twin
window units, I use a straightedge to make sure there are no
humps or dips in the stool.
Figure 4.The author uses a level as a straightedge
when shimming the stool, which results in an even reveal along
the bottom edge of the window.
I also use the straightedge to check the window jambs. While
the windows may not always be perfectly plumb, it's more
important that the jambs and their extensions are straight and
square. When the head jamb extension is centered with an even
reveal at each side jamb, I check the side jambs and extensions
with the straightedge, shim to fit, then secure the jamb
extensions and stool by nailing through the shims into the
framing.
Tight Miters
After I've installed the jamb extensions, I begin casing the
window by first marking the 1/4-inch reveals along the faces of
the jambs with a tri-square (Figure 5). Most of the time, I'm
installing a profiled casing with mitered corners, which
typically requires more careful fitting than flat casings with
butt joints. I get the best results by nailing both of the side
casings on first, then fitting the head casing.
Figure 5.After marking the 1/4-inch reveals around
the perimeter of the window (top), the author sets the side
casings in place on the window stool and transfers the mark to
the casing (middle right). Before fitting the top casing, he
back cuts the miter cut slightly with a block plane to ensure a
tight fit (middle left), joins the miter together with glue,
and cross-pins the joints (bottom).
Rather than use a tape measure, I mark the side casings in
place, using my reveal markings on the jambs. After cutting the
45-degree miters, I like to block-plane a little back relief on
each miter cut, which makes it a lot easier to get a tight
joint later on.
With the side casings nailed in place, I cut the head casing
about 1/8 inch too long. This allows me to check the fit at
each corner when I'm centering the head casing, and to make
small adjustments in the miter cuts for near-perfect joints. I
think it's worth making a couple of extra cuts to get great
joints. Also, with the back-cut on the casing miters and the
2-degree bevel on the outer edge of the jamb extensions, I can
get tight miters even if the jamb extensions are slightly proud
of the wall in spots. No matter what type of material I'm
using, I always glue and cross-pin the joints.
Three-Piece Apron Dresses Up the
Trim
Finally, I build a detailed apron by wrapping the two long
edges of a 1x3 with a decorative molding (Figure 6). For this
window, I used stock panel molding, but any base cap or similar
molding that has a square shoulder would also work.
Figure 6.The 1x3 apron is wrapped with panel
molding top and bottom (top). The author glues and pins the
small pieces together with a 23-gauge headless pinner (middle),
then installs the apron in one piece (bottom).
Building up a three-piece molding is a lot more work than using
the standard piece of casing as the apron. By the time you've
completed the last return of panel molding, you've actually cut
and assembled seven pieces, including the four mitered returns.
But I've found that just about everything in construction that
looks better requires a little extra work.
To find the length of the 1x3 apron, I measure across the
window from outside to outside of the casing and subtract 1 1/2
inches to allow for the two 3/4-inch-thick molding returns.
After cutting the 1x3 to length, I typically glue and nail in
place the panel molding pieces that wrap the top and bottom of
the apron. I use a 23-gauge headless pinner for this because it
won't split the short return pieces of molding, and it leaves
small holes that are easily filled.
The last step is nailing the apron assembly under the stool. I
take care to center it accurately, using centerline
measurements marked on both the apron and the drywall, since
any offset will appear visually exaggerated by the built-up
trim. If I have done everything right, the outside edges of the
panel mold returns should line up with the outside of the
casing trim.
Gary Striegleris a builder in
Springdale, Ark.
