A. Mike Casey, a licensed
plumber in Connecticut and California and co-author
of Code Check Plumbing, responds: Although black
iron pipe is a bit less expensive, galvanized pipe
offers better corrosion resistance. In my
experience, both types of piping work fine, and the
IRC and the National Fuel Gas Code allow both
— along with corrugated stainless steel
tubing (CSST) and copper tubing (with some
limitations) — to be used for natural gas
distribution piping.
But you’re right: Some municipalities,
particularly in the Northeast, still allow only
black iron for natural gas piping. This is probably
because the quality of natural gas once varied more
widely than it does now, and local contaminants
like hydrogen sulfide could cause problems with
certain types of piping.
For example, natural gas with a significant
amount of hydrogen sulfide and moisture in it can
react with copper tubing, leading to black flaking
within the system. Or, sulfur in the gas can react
with the zinc coating in galvanized pipe, causing
it to flake off. Because these flakes can clog the
small openings in gas-burning appliances, some
model codes have prohibited the use of galvanized
and copper gas lines.
But natural gas is much cleaner than it was 40
years ago, and nearly all fuel gas goes through a
sulfur recovery unit before it enters the
distribution system these days. Also, fuel-gas
piping installations now require that drip legs or
sediment traps be installed at the horizontal
connection to the appliance to collect any moisture
or debris flakes flowing with the fuel gas.
Still, even though fuel gas has been cleaned up,
some states haven’t changed their codes to
permit galvanized pipe or copper tubing. I
recommend that you contact the people at your local
building and safety department and use the piping
they specify for your specific fuel-gas
installation.
