Gel coat.
The next day’s work begins with more sanding (Figure
10).
Figure
10. After the base coat has dried, sandpaper is used to
knock down edges and rough up the whole surface to improve
bonding with the finish coat (left). Brooms and leaf blowers
are used to remove excess particles from the surface before
applying the gel coat finish (right).
Using a 36-grit sanding disc on a grinder, all of the frayed
seams at the drip edges are sanded back to true the edges; the
rest of the surface is sanded to remove any lumps and to rough
up the base for good bonding. In final preparation for
application of the gel coat, dust and residue from the sanding
are cleaned off the deck using brooms and gas-powered leaf
blowers.
The gel coat Rick and Dan use is formulated for exterior
applications and contains UV inhibitors as well as additives to
increase abrasion resistance (Figure 11).
Figure
11. Tinted gel coat is applied first at edges and
penetrations (top left), then on the main deck (top right),
using short-nap paint rollers. The final product cures in about
30 hours and looks much like the surface of a fiberglass tub
(bottom).
It is also available in several colors; on this job, we used
beige for the decks and white for the continuous rail capping
the 3-foot tall bulkhead walls that were used instead of posts
(Figure 12).
Figure
12. On this job, the wood railings were also flashed
with fiberglass mat (left), then finished with white gel coat
to contrast with the deck color (right).
Once the resin is mixed with hardener, application begins at
the edges and proceeds to the field. As with the base coat, the
gel coat is applied using throwaway paint rollers. The finished
product looks similar to the surface of a fiberglass tub,
except slightly rougher, because it picks up the texture of the
glass mat below, and also because of the nonskid surface
provided by the sand. We allow the gel coat to cure for 30
hours before we set the doors. We always work while standing on
sheets of plywood placed on the deck, because at this point the
gel coat is not fully cured. Even after the surface is cured,
we always work off of the plywood to protect the surface. The
gel coat will take a lot of abuse, but early on it’s
still tender. Nothing will ruin a day faster than dropping your
hammer off of a 6-foot ladder and putting a chip in the new
surface.
Details & Maintenance
Siding is installed as usual, with the building paper
overlapping and taped to the fiberglass where it runs up the
wall. At railings, we have had problems in the past with
checking of the wood posts, which allows water past the
fiberglass counterflashing and into the building envelope. Now
we usually wrap our posts with 1x6s, holding the boards 1/2
inch off the surface of the deck to prevent wicking of
moisture. In the search for the perfect railing, we have tried
a few vinyl systems. The vinyl post covers that come with some
of these systems work fine.
Routine maintenance of the fiberglass deck surface is the
same as any fiberglass boat. The surface should be cleaned
periodically with a non-abrasive cleaner, such as Spic ‘N
Span, and visually inspected every year for signs of excessive
wear, especially at the deck-wall junction and around the
posts. We have decks out there that are 10 years old and have
needed nothing more than an additional application of gel
coat.
Repairs are fairly easy. The affected area is removed, the
edges of the fiberglass are ground back, and the plywood is
reinforced to ensure a sound surface. Then the fiberglass is
reapplied to make the patch. The gel coat blends almost
perfectly.
Eric Borden owns ESB Contracting, a remodeling company
in Forked River, N.J.
