A.Sean Gerolimatos,
technical services manager for Schluter Systems,
responds: With a few exceptions, unmodified
thinset mortar is required for setting ceramic and
stone tile over Kerdi membranes (800/472-4588,
www.schluter.com ), as well as for bonding
overlapped seams and connections to Kerdi drains. A
blend of portland cement, sand, and water-retention
agents, this type of mortar — sometimes
referred to as dry-set mortar — is simply
mixed with water (look for the ANSI A118.1 standard
on the packaging).
Modified thinset mortars are similar but include
additional polymers — such as latex
— which are introduced in either liquid or
powder form. For the liquid form, an unmodified or
dry-set mortar powder is mixed with a liquid
polymer additive instead of with water. For the
powder form, the manufacturer adds powdered
polymers to the dry blend, and this is mixed with
water (look for ANSI A118.4 and ANSI A118.11
standards on the packaging).
Modified thinset mortars aren't recommended for
use with Kerdi because they must dry out to gain
strength, whereas the membrane inhibits drying,
which can lead to unpredictable results. For
example, if a shower is used before the mortar has
cured properly, leaks and polymer leaching can
occur. Unmodified thinset mortars, on the other
hand, depend on the presence of moisture to gain
strength, and therefore they are well-suited for
these curing conditions.
Schluter's recommendation is to use unmodified
thinset mortar when installing Kerdi over most
shower substrates. In principle, modified mortars
also could be used over water-absorbing substrates
such as drywall, cement backerboard, or dry-pack
mortar — but seams and connections to the
Kerdi drain would still need to be constructed
using unmodified thinset mortar. Frankly, working
with more than one type of mortar seems
unnecessarily complicated.
