Choosing a Power Planer, continued
PLANER PROFILES
Bosch 3296K
This is an accurate, well-made machine. The front shoe rides
up and down on sloped ways, and the depth-of-cut settings are
especially easy to gauge. The 3296K comes with one of the
nicest adjustable fences I've ever used. Chips can be ejected
from either side of the planer, though the mechanism for
changing sides was sticky on the particular tool I tested. This
tool is powerful enough to make a 3/32-inch cut, but the
exhaust chute tends to clog when you do it. The 3296K is
comfortable for right-hand use, but the trigger safety makes it
awkward for left-hand use.
Bosch 3365
This planer is small, light, and very maneuverable. Chips can
be ejected from either side of the tool. The 3365 runs at a
slightly higher rpm than other planers and uses a single blade.
According to the manufacturer, this cuts your blade costs
because when you hit a nail, you only ruin half a set. This
tool runs so smoothly that I couldn't tell from use that it has
only one blade. This model has a 10-foot cord and comes with a
simple 90-degree fence. Chips can be ejected from either side,
but the chute will clog if you cut too quickly. The blades are
held in place by a single pair of set screws, so changes are
quick and nearly idiot-proof.
Craftsman 27716
This retro-looking tool has indexed depth settings and
easy-to-change bolt-on carbide blades. Chips are ejected to the
right through an adjustable nozzle that can be aimed away from
the user. This Craftsman planer comes with a single-piece
5-degree door beveling fence that screws to the side of the
housing. The fence may not look like much, but it does the job.
Unfortunately, this tool is under-powered for its size. The
motor labored and the exhaust chute frequently clogged during
full-depth cuts on 1 1/2-inch-wide joists.
DeWalt DW678K
The DW678K is big and powerful, though somewhat heavy. With a
cutting capacity of 5/32-inch, it's tied with Festo for maximum
listed depth of cut. However, this tool tends to clog during
full-depth cuts, even on 1 1/2-inch stock. On the plus side, a
removable sleeve in the chip chute makes it safer and easier to
clear blockages. And the sleeve is reversible, so chips can be
ejected from either side of the machine. This tool has a very
comfortable grip, but if you're a left-hander, you need to be
careful not to accidentally engage the trigger lock with the
palm of your hand. I like the indexed depth settings and the
way the parking foot locks up out of the way for cuts that
start in the middle of a board.
DeWalt DW680K
The DW680K doesn't have every feature you can get on a power
planer, but the ones it has work just fine. It's light and easy
to handle, and the motor shows no strain during full-depth
(1/16-inch) cuts. Although the chip chute only ejects to the
right, it rarely gets clogged. This tool has a long cord,
indexed depth-of-cut settings, and a parking foot that can be
locked out of the way. It comes with a simple 90-degree fence
and a sturdy metal case. The only thing I don't like about this
tool is the trigger lock, because it's located in such a way
that a left-hander could accidentally activate it.
Festo HL850E
If power planers were cars, Festo's would be a Rolls-Royce. It
uses a single disposable spiral-cutting carbide blade. The head
is removable and can be swapped out for optional heads that
produce a variety of textured surface finishes. For example, I
tried one that uses a convex blade to plane adze-like cuts in
the surface of beams — something a timber-framer might
like. The blade comes flush to the right side of the motor
housing, so there's no limit to the depth of rabbet cuts. This
means that the HL850E can plane all the way into an inside
corner, like the joint between the baseboard and flooring. This
tool is exceptionally quiet because it runs at a constant speed
of 10,000 rpm. The standard dust bag actually works, and you
can get an optional angle fence. This is easily the most
versatile planer I tested, but at a cost of over $400, it's
more planer than most carpenters can afford.
Freud FE82
The FE82 is a well-made tool with simple solid features. Cuts
come out straight because the front and rear shoes remain
parallel at all depth settings. It comes with a rigid 90-degree
fence and a vacuum adapter. Blades are easy to change, but I
didn't like the short cord or the way the parking foot gets in
the way when you start cuts in the middle of the board. Except
for the low price, there's nothing very special about this
tool.
Hitachi P20SB
This tool is light, simple, and inexpensive. In terms of
usage, it's a good general-purpose planer. But in terms of
features, it's a throwback to the sort of planer I was using 15
years ago. It doesn't matter that the tool doesn't have a
parking foot, and it's not a deal breaker that the chips only
eject to the right. But the P20SB doesn't use the disposable
carbide mini-blades that are now standard on nearly every
planer; instead, you have to use a clunky knife-setting jig, so
changing blades is more of a hassle than it should be.
Hitachi P20DA
This is a very interesting new tool, a 12-volt cordless
planer. The P20DA is about the same size and weight as
Hitachi's corded model, though the location of the battery
makes it noticeably tail-heavy. As you would expect, it's
significantly less powerful than a corded tool, which is why
the maximum depth of cut is only 1/64 inch. The tool does a
good job making light finish cuts, but isn't up to planing
framing stock. The manufacturer claims that it will plane 100
feet of 1 3/4-inch stock on a single charge. That seems about
right: I tested it on the edge of a 2x12, and it cut 112 feet
before the battery gave out. Unlike Hitachi's corded model,
this one uses disposable carbide mini-blades.
Makita N1900B
This tool is nearly indistinguishable from the planers Makita
was making 15 years ago. It's a simple, straightforward machine
without a lot of bells and whistles. Like its predecessors, the
N1900B clears chips well and comes with a short 90-degree
fence. Unlike the original model, this one takes standard
carbide mini-blades. It's reasonably powerful for a 5 1/2-pound
tool, but in its factory configuration it is limited to a
1/32-inch cut.
Makita 1050DWA
This planer proves how deceiving looks can be. When I opened
the box, I thought it was a toy, but once I started using it, I
was impressed by how well it worked. I was especially impressed
by the amount of work it can do on a single charge. According
to the manufacturer, it can plane 140 feet on a single charge,
but I managed to get 232 feet planing the edge of a 2x12. The
1050DWA is smaller and lighter than Hitachi's cordless model
but is limited to making 2-inch-wide cuts. The narrow cutting
width is a reasonable compromise, given that no cordless planer
is really up to making 3 1/4-inch cuts. I wouldn't use the
1050DWA to straighten framing, but I could see buying one to
scribe cabinets or plane the occasional door. At $290, it's
definitely a luxury item, one that's easier to justify if
you're already using Makita's 12-volt system.
Metabo 0882
This tool exhibits the same European sensibility that Festo's
and Bosch's planers do. It has precise indexed depth settings
and a front shoe that's always parallel to the rear shoe. The
chip chute ejects from either side and can be switched by
flipping a baffle. The spring-loaded parking foot is better
than most in that it's heavy enough to stand up to abuse but
doesn't get in the way because it retracts when you push down
on it. This tool has plenty of power, even at the full 1/8-inch
depth of cut. The 0882 has an exceptionally long cord and comes
with a 90-degree fence. My only complaint about this planer is
that it doesn't come with a case.
Porter-Cable 125
The best thing about this tool is that it's powerful and
capable of making nice deep cuts. It's also a plus that it
comes with an adjustable bevel fence. The shoes on the planer I
tested, however, went out of parallel at maximum depth of cut.
As a result, deep cuts tended to be bowed cuts. You have to
rotate the control knob multiple times to move between minimum
and maximum depth settings, and the numbers on the depth scale
overlap, so it's easy to lose track of exactly where you are.
This tool is light and well balanced, but a safety makes it
awkward for left-hand use. Exhaust is to the right side only.
It's a minor point, but the fence fit so tightly in the molded
plastic case that I had to pry it out with a screwdriver.
Porter-Cable 126 (Porta-Plane)
After having been around for years, the Porta-Plane was
discontinued a couple of years ago. However, there was such an
outcry that the manufacturer brought it back as the model 126.
Unlike most of the planers I tested, this tool is designed to
plane long narrow pieces of stock — in particular, the
edges of doors. It has a 16-inch base and a long, nonremovable
fence that tilts from minus 15 degrees to plus 45 degrees. An
adjustable stop allows you to preserve preset angle settings.
The front shoe moves smoothly up and down by moving a lever on
the front of the housing. The base is only 2 1/4 inches wide,
but that's plenty for most doors. The Porta-Plane takes a
spiral-cutting head that is easily removed for sharpening.
Except for the cap on the end of the motor housing, this is an
all-metal machine.
Virutex CE96H
When I was in boat-building school, I once joked that someday
I'd throw away my old-fashioned compass plane and replace it
with a power-driven model. That got a good laugh, because at
the time there was no such thing as a power compass plane. But
several years ago, Virutex introduced the model CE96H. It's
just like any other power planer except that the base is made
from a thin, flexible sheet of metal. As a result, the base can
be adjusted to follow inside and outside curves. The minimum
concave radius it can do is 17 3/4 inches; the maximum convex
radius is 15 3/4 inches. Although it's power driven, it still
takes finesse to use this tool. That said, if you're one of
those rare carpenters who planes a lot of curves, this might be
the planer of your dreams.
PLANER SPECS
Manufacturer | Model | Street Price | Weight (lbs.) | Cord Length | Motor Rating | Max. Depth of Cut | Width of Cut | Length (front to back along
the base) |
Bosch | 3296K | $179 | 6.4 | 6' 8" | 6.5 amps | 3/32" | 3 1/4" | 11 1/2" |
Bosch | 3365 | $109 | | 10' | 5.0 amps | 1/16" | 3 1/4" | 9 7/8" |
Craftsman | 27716 | $139 | 7.8 | 10' | 5.5 amps | 1/16" | 3 5/8" | 10 3/4" |
DeWalt | DW678K | $249 | 9.2 | 9' 4" | 7.8 amps | 5/32" | 3 1/4" | 12 1/2" |
DeWalt | DW680K | $161 | 5.5 | 9' 4" | 5.2 amps | 1/16" | 3 1/4" | 11 3/8" |
Festo | HL850E | $436 | 8.6 | 12' 8" | 7 amps | 5/32" | 3 1/4" | 13 5/8" |
Freud | FE82 | $109 | 6.5 | 7' 6" | 6.2 amps | 3/32" | 3 1/4" | 11 1/4" |
Hitachi | P20SB | $114 | 6.1 | 8' | 3.4 amps | 1/32" | 3 1/4" | 11 5/8" |
Hitachi | P20DA | around $250 | 6.4 | n/a | cordless 12-volt | 1/64" | 3 1/4" | 11 5/8" |
Makita | N1900B | $139 | 5.5 | 8' 9" | 4.0 amps | 1/32" | 3 1/4" | 11 1/2" |
Makita | 1050DWA | $290 | 4.6 | n/a | cordless 12-volt | 1/64" | 2" | 9" |
Metabo | 0882 | $225 | | 14' | 6.5 amps | 1/8" | 3 1/4" | 11 1/2" |
Porter-Cable | 125 | $149 | 5.5 | 9' | 6 amps | 1/8" | 31/4" | 11 1/4" |
Porter-Cable | 126 | $399 | | 10' | 7 amps | 3/32" | 2 1/4" | 16" |
Virutex | CE96H | $325 | | 7' 8" | 6.7 amps | 1/8" | 3 3/16" | 9 1/2" |
Manufacturer | Model | Max.
Rabbet Depth | RPM | Blade
Type | Standard
Accessories | Place of
Manufacture |
Bosch | 3296K | 15/16" | 13,000 | standard inserts | steel case, angle fence,
rabbeting depth stop | Switzerland |
Bosch | 3365 | 5/16" | 18,000 | standard inserts | 90-degree fence, vacuum
adapter | Switzerland |
Craftsman | 27716 | 3/16" | 16,000 | Craftsman-brand blades | 5-degree door beveling
fence | USA |
DeWalt | DW678K | 1" | 12,000 | standard inserts | metal case, rabbeting depth
stop, 90-degree fence | England |
DeWalt | DW680K | 1/2" | 15,000 | standard inserts | metal case, 90-degree fence | England |
Festo | HL850E | unlimited | 10,000 | Festo spiral inserts | plastic case, dust bag, rabbet
depth stop, and 90-degree angle fence | Germany |
Freud | FE82 | 1/8" | 14,000 | standard inserts | case, dust collection nozzle,
90-degree fence, rabbeting depth stop | Spain |
Hitachi | P20SB | 15/64" | 15,000 | Hitachi-brand blades | case, straight guide,
blade-setting gauge | China |
Hitachi | P20DA | 15/64" | 13,000 | standard inserts | battery, charger, plastic case,
90-degree fence, 2-amp hour battery | Japan |
Makita | N1900B | 11/32" | 15,000 | standard inserts | plastic case, 90-degree
fence | USA |
Makita | 1050DWA | 9/16" | 9,000 | Makita inserts | plastic case, 90-degree fence,
battery, charger, dust bag, 2-amp hour battery | Japan |
Metabo | 0882 | 7/8" | 12,000 | standard inserts | rabbet depth stop, 90-degree
fence, dust collection nozzle | Germany |
Porter-Cable | 125 | 7/8" | 14,000 | standard inserts | plastic case, bevel fence,
rabbeting guide | Italy |
Porter-Cable | 126 | n/a | 23,000 | removable spiral head | metal case, permanent fence
15 degrees to +45 degrees | USA |
Virutex | CE96H | n/a | 16,500 | standard inserts | fence | Spain |
Bosch S-B Power
Tool
Chicago, IL
877/267-2499 www.boschtools.com Craftsman Sears Power Tools
Garland, TX
800/377-7414 www.sears.com/craftsman DeWalt Industrial Tool
Hampstead, MD
800/433-9258 www.dewalt.com Hitachi Power Tools
Norcross, GA
800/546-1666 www.hitachi.com/powertools Festo ToolGuide
Santa Barbara, CA
888/463-3786 www.toolguide.net | Freud
U.S.A.
High Point, NC
800/472-7307 www.freudtools.com Makita U.S.A.
La Mirada, CA
800/462-5482 www.makitatools.com Metabo
West Chester, PA
800/638-2264 www.metabousa.com Porter-Cable
Jackson, TN
800/321-9443 www.porter-cable.com Virutex
New York, NY
212/989-9868 www.virutex.com |
