A.A considerable
quantity of moisture is reaching the north attic
from below. Once the moisture is in the attic, it
condenses on the coldest surface — usually
the roof sheathing. Most condensation occurs at
night, when the roof is coldest. The problem occurs
only on the north side because the sun evaporates
the condensation on the south side on a daily
basis. The moist air is then vented through the
soffit and ridge vents. On the north side, which is
not sufficiently warmed during the day, the frost
continues to build, until a really warm day comes
along and the entire frost coating melts, producing
the problem you describe.
During the first winter after construction, a
major source of moisture can be the construction
materials themselves. With a block foundation,
there can be at least a ton of moisture lost from
the mortar, wood, paint, and drywall taping
compound in the house. In a house with a poured
concrete basement, the amount may be several tons.
The problem often disappears after the first
winter.
Additional moisture may be coming from a damp
crawlspace or basement, excessive use of a
humidifier, or a gas-burning appliance, such as a
water heater or furnace that is not venting
properly. A plumbing wall or flue chase can provide
a direct path to the attic from the basement if
these passages are not sealed at the ceiling
level.
You may be able to isolate the problem by
"reading" the indoor humidity levels in the house
on the windows. If there is condensation on
double-glazed windows, the indoor humidity is too
high and ventilation fans in the kitchen and
bathrooms should be run continuously until the
condensation goes away. If condensation occurs on
the windows on only one side of the house, the
problem may be caused by the use of a humidifier or
improper venting of gas-burning appliances. If
there is no condensation on the windows, the
moisture is probably coming from the basement or
crawlspace through the plumbing or flue chases.
