A.Bill Rose, architect and
building researcher at the University of Illinois
Urbana-Champaign, responds: There are four
purported reasons to vent an attic space. The first
is moisture control. Moisture control matters in
the northern states, but in the humid South, only
carpetbaggers would say that venting is necessary
for moisture control.
The second reason for venting attics is to
reduce ice dams, which are not a problem in
Virginia. The third reason is to enhance the
service life of asphalt shingles. How much effort
and expense are you ready to put out so that the
roof lasts 22 years instead of 20 years? (Use your
own estimates of how long shingle roofs last
— these are my personal guesses based on
my own roof.)
The fourth reason is for comfort and savings
during the summer cooling period. In your case,
judging from the presence of a thermostatically
controlled fan, I would guess that this is the main
reason — to keep the attic air temperature
as cool as possible. If it’s comfort and
savings you want, ceiling insulation comes first.
The gable fans might actually be counterproductive,
since they might be sucking good air-conditioned
air out of the house and into the attic. If there
is ductwork in the attic, try to relocate it into
the conditioned space, or at least correct any
leaks or poor duct insulation.
Once you’ve sealed all of the openings
that lead from below into the attic, corrected the
ductwork, and installed a nice thick blanket of
insulation in the attic, then one venting strategy
is about as good as any other. Gable venting and
ridge venting are both fine. Soffit venting with
baffles is fine. Combinations are fine. If parts of
the roof have a lot of venting and other parts have
little or none, most would agree that
that’s fine too. Power venting, however,
is noisy and expensive.
