Floor Framing With Steel Continued
Framing a second floor. If the second-floor
steel joists are supported by a wood-framed wall, the procedure
is almost the same: The rim track is screwed to the top plate
and the joists are screwed to the track. On a steel-framed
wall, the rim track is screwed to the top track (the steel
equivalent of the top plate) of the supporting wall, and the
bottom flanges of the joists are also screwed to the top track
(Figure 7).
Figure
7. Second-floor joists are fastened to the top
track of a steel-framed wall with screws driven through
the joist flanges. OSB sheathing will be screwed to
both studs and rim track for a secure connection
between floor and wall framing. |
Web stiffeners are usually required at the joist ends, as
for the first floor. Cantilevered joists also require a web
stiffener where they pass over the supporting wall (Figure
8).
Figure
8. A framer clamps the cantilevered floor joist
to the top track before screwing it in place.
Additional web stiffeners will be added where the
joists bear on the plate. Floor cantilevers of up to 2
feet are permitted by the prescriptive
method. |
Regardless of whether the walls are framed with wood or
steel, the upper edge of the OSB will fall about one foot below
the rim track, provided that the first course of OSB starts at
foundation level, as described earlier. The next sheet of OSB
ties the second-floor rim joist solidly to the studs and plate
beneath.
Clip angles and nested assemblies. Framing
openings in a steel floor is similar to framing openings with
wood. In place of the traditional double trimmer at each side
of the opening, a nested assembly consisting of a C-joist and a
track section is used (Figure 9 below). Steel headers are
assembled the same way. Connections are made with screws and
clip angles, which are the steel framer's equivalent of joist
hangers.
Framing Floor Openings |
Figure
9. Floor openings are simple if you think of
nested track and joist sections as double trimmers or
headers, and clip angles as joist hangers. |
