- Q.In New York state, we built a pergola (a type
of garden trellis) using 8x8 pressure-treated posts set 4 feet
into the ground. During the first winter, the frost lifted the
posts. What should we have done to keep the posts from
heaving?
A.Ron Hamilton, owner of Hamilton General
Contracting in Saylorsburg, Pa., responds: For structural
reasons, pergola posts should be deeply buried. (In contrast,
when building a deck, it’s better to set the
pressure-treated posts on top of Sonotubes extending above
grade.) In order to help resist wind uplift, pergola posts
should be embedded in concrete, rather than in holes backfilled
with dirt. But if the holes are backfilled with concrete, the
concrete conforms to the irregular shape of the hole, allowing
frost to grip the concrete and heave the post. I prefer to
insert the buried section of the post into a Sonotube.
Check with your local building officials for information
regarding the frost depth in your area. Your post holes should
be dug to the frost depth plus 6 inches. Each hole should
receive 6 inches of crushed stone for drainage. Drainage is
important, since frost heaving is more likely in wet soil than
dry soil.
The Sonotubes should extend from the crushed stone base to
slightly above grade. After backfilling around the Sonotube
with compacted dirt, insert the pressure-treated posts inside
the Sonotube, holding the bottom of the posts about 6 inches
above the crushed stone, to provide a space where concrete can
flow under the posts. Then plumb and brace the posts and fill
the Sonotubes with concrete.
