At age 54 and a couple of years after heart surgery, I
appreciate less physically demanding labor. I also appreciate
equipment that increases the profitability of my small
contracting business, which specializes in building and
repairing wooden fences. So, recently I field-tested four
different models of mini skid steers — the Toro Dingo TX
420, the PowerHouse Pro, the Bobcat MT52, and the Ditch Witch
SK500 — to find out how well they perform in the kind of
work that I do.
A mini skid steer is basically a self-propelled hydraulic power
plant, a walk-behind version of the larger skid steers you see
people driving around construction sites.
Depending on the make and model, mini skid steers are available
with rubber wheels or rubber tracks. As with the larger
"riding" models, the skid steer and its attachments are driven
by a small diesel or gasoline engine. The machines I tested
have the power to lift more than 500 pounds or to run a
30-inch-diameter auger up to 4 feet deep. Attachments include a
traditional bucket, pallet forks for material handling, a snow
thrower, dozer and grader blades, a power broom, and a backhoe.
With the right attachments, you can grind stumps and shred
limbs, mix cement and break up concrete, or till and trench
soil. Best of all, a mini skid steer is less than 3 feet wide,
so you can take it through narrow openings and use it where
larger machines won't go.
At a base price of $15,000 to $20,000, a mini skid steer is a
sizable investment. Nonpowered attachments cost around $500,
while hydraulically powered ones start at $1,800 and can cost
more than $7,000. Renting a machine is an option, but for my
kind of work, labor savings would more than offset the $400 to
$500 monthly payment required to finance one. For example, the
average fence requires about 30 heavy, pressure-treated 4x4
posts, a load I can carry in one trip with one of these
machines. I also use about 500 pickets for a fence, which, with
my mini skid steer, I can carry into the backyard in two
trips.
Toro Dingo TX 420
Toro started the revolution in mini skid steers with its Dingo
series of compact utility loaders (estimated list price
$17,500, The Toro Co., 800/348-2424,
www.toro.com). Other manufacturers have
since jumped on the bandwagon, and in fact most of the
available attachments are now interchangeable among these
machines. Powered by an air-cooled, 20-hp industrial Kohler
gasoline engine, the Dingo has a unique controller that struck
me as intuitive and ultrasimple to use, even for a
novice.
The Toro Dingo features intuitive,
easy-to-use controls and is available in both wheeled and
tracked versions.
However, a quick look under the hood revealed a couple of
potential problems. One is the hydraulic fluid overflow, which
is aimed directly at the drive belt, an arrangement that could
easily render the whole machine inoperable. Also, the oil-drain
plug looks to be rather inaccessible.
A more serious flaw in the Dingo's design is that it can tip
backward if you attempt to drive up too steep a grade. During
my initial demonstration, the salesman who was showing me how
to use the machine was very careful to load it onto the trailer
by backing up the drive ramp.
The Dingo TX 420 has a track drive, but Toro also makes wheeled
versions. While I didn't test them, I suspect that stability
would be even more of a problem with those models.
PowerHouse Pro
The PowerHouse Pro ($16,945, Compact Power Inc., 800/476-9673,
www.powerhouseequipment.com), which is
available for rent at Home Depot, was the only rubber-tired
model I tested. Though the 24-hp gas motor gives it plenty of
power, it has a short and narrow wheelbase — like all
wheeled mini skid steers — that makes it very unstable on
hills.
Although the PowerHouse Pro's rubber
tires are gentle on grass, its short and narrow wheelbase makes
it tippy and potentially dangerous on uneven or hilly
terrain.
Compounding the problem, the controls of the PowerHouse Pro
seemed to be very jumpy. In fact, I rented it twice and tipped
it over twice, both times on a slope. (In defense of
PowerHouse, the company also makes a tracked unit called the
Prowler, which I didn't test.)
If you're doing any work at all on a hilly site, I wouldn't
recommend the PowerHouse Pro or any other wheeled
machine.
Bobcat MT52
Whether you opt for a wheeled or a tracked unit depends on the
kind of work you'll be doing and the kind of terrain you'll be
working on. While the Bobcat MT52 (estimated list price
$17,500, Bobcat Co., 701/241-8700,
www.bobcat.com) feels stable, its tracks
were hard on turf grass and the lugs on the semiflotation
tracks vibrated unpleasantly on paved surfaces, as if riding on
a flat tire.
The Bobcat MT52's 18.8-hp diesel engine
generates enough low-rpm power to drive this hydraulic breaker.
Here, the machine is equipped with an optional ride-on
platform.
The MT52 is a vast improvement over Bobcat's first mini
skid-steer design, the MT50, which was controlled by tricky
joysticks similar to those found on the company's full-sized
skid steers. Also, the MT50's hydraulics caused the machine to
lurch suddenly, like revving an engine and popping the clutch.
Because the Dingo was so much easier to use, Bobcat totally
redesigned its machine, changing the drive system to a
hydrostatic drive, simplifying the controller, and renaming it
the MT52. (Incidentally, don't buy a used MT50 no matter how
good the deal sounds: The machine is definitely
inferior.)
Today, the primary difference between the Toro and the Bobcat
is in the two machines' power plants. The MT52 has Kubota's
18.8-hp liquid-cooled diesel engine, which is well-suited for
low-rpm work and should have a long service life. The downside
is that you have to breathe unpleasant diesel fumes. Also, the
Bobcat's engine compartment is crowded, which might make engine
servicing difficult.
Ditch Witch SK500
Although I know I'd be happy with either the Bobcat or the
Toro, my favorite skid steer is the Ditch Witch SK500 ($17,995,
The Charles Machine Works, 800/654-6481,
www.ditchwitch.com). Its 24-hp Honda motor
has 20 percent more horsepower than either the Bobcat or the
Toro, and it's set lower in the engine compartment for much
better balance.
The Ditch Witch SK500's long,
width-adjustable tracks provide extra stability on uneven
ground. It has a 24-hp gas-powered engine.
The machine's longer tracks make it harder to tip than the Toro
Dingo, and instead of a vulnerable drive belt, it features a
more robust direct-drive connection to the drive shaft. This
also creates more room in the engine compartment, which should
make servicing easier.
The full metal hood feels more rugged than the plastic hoods I
found on the other machines, and I like all of the tie-down
points and the heavy D-rings. There's a fuel cutoff for safe
traveling; a convenient power port with a cigarette-lighter
socket; and lockable hood, gas, and hydraulic fluid covers, a
clever feature in this day and age of equipment
vandalism.
Perhaps best of all, you can adjust the width of the tracks, a
feature unique to the SK500. By loosening and tightening four
bolts, you can slide the tracks out for more stability in tough
conditions, then slide them back in to fit through a narrow
fence gate.
The SK500's one drawback is the engine noise; it's the loudest
of the pack.
John
Wilderis a fencing contractor
near Daytona Beach, Fla.
HOME-INSPECTION TOOLSSewer Sleuth. Ten years ago, when I was
rehabbing turn-of-the-century houses around Pittsburgh, I had
several callbacks for problems with underground waste lines.
The 100-year-old sewer pipes worked fine with occasional water
use, but sometimes issues would surface once the house was
occupied. I could have taken care of those problems before
occupancy had I included a comprehensive check with a
pipe-inspection camera as part of the plumbing contract. The
Compact SeeSnake is a good example of just such a camera. It
can travel up to 100 feet through 11/2- to 4-inch drain lines
and it includes a transmitter for determining the exact
location of underground breaks or obstructions. You can even
connect the color monitor to a VCR so that you have a permanent
record of the pipe's condition. The camera sells for about
$4,800. Ridgid, 800/769-7743,
www.ridgid.com
Flow Chart. With the increasing popularity of
multihead showers, lawn-irrigation systems, and even multiple
dishwashers, modern homes can use a huge amount of water. If
you're wondering whether your customers will have adequate
water volume or water pressure for their needs, you can use a
Volume and Pressure Gauge (model 53351) from Toro to find out.
Designed for irrigation-system installers, the gauge measures
static pressure of up to 160 pounds and peak flow of up to 13
gallons per minute. It connects to any hose bib and sells for
about $100. Toro Irrigation, 800/664-4740,
www.toro.com
X-Ray Vision. I don't know any remodeler who
hasn't wished at least once that he or she had X-ray vision.
After all, few of the surprises found inside the walls, floors,
and ceilings of old houses are good ones. Luckily, you can
minimize the unknown with a ProVision Boroscope. This tool uses
6,000 optical fibers and a .4-inch flexible cable with a
built-in light to enable you to see inside inaccessible spaces
without destructive investigation. Models with inspection
cables from 18 to 96 inches are available. Prices start around
$200. CML Innovative Technologies,
888/398-1522, www.provision100.com
Crack Tracker. Need to determine whether a
crack in masonry or concrete is spreading, shrinking, or
signaling a more serious differential movement? There's really
only one way to know conclusively: Use a Crack Monitor. Made
from two overlapping acrylic plates — one with red cross
hairs and one with a graduated scale — the monitor
straddles the crack and quantifies any changes. Long-term
monitoring can indicate whether environmental conditions such
as freezing temperatures or expansive soils are at work. The
device sells for $16 on the company's Web site.
Avongard, 800/244-7241,
www.avongard.com
WORK
WEAR
Formal Wear. For many builders and remodelers, a polo
shirt is the standard summer uniform for client meetings and
sales presentations. But there's a problem: Most of these
shirts just aren't designed for people who work for a living.
The Top Shelf No-Polo from Duluth Trading promises to be the
polo shirt for people who don't play polo. Made from fabric
that's 50 percent thicker than that of other polos, the No-Polo
provides superior freedom of movement and has an extra three
inches in the back to conceal your bottom line. The garment is
available in sage green, navy, and yellow; it sells for about
$33. Duluth Trading, 800/505-8888,
www.duluthtrading.com
Stink-Free Tee. Keeping comfortable and
smelling sweet during the workday is easier with a Performance
Work Shirt from Gorgonz. The manufacturer claims the new shirt
breathes four times better and dries four times faster than a
100 percent cotton tee. It's designed to last longer than your
average work shirt, too, with heavy-duty stitching and
reinforcement in areas prone to wear. The fabric even boasts a
built-in odor neutralizer, so you can meet with clients without
them thinking you're stinking. Two breast pockets and a sleeve
pocket hold small articles that might otherwise sink to the
bottom of your toolbelt. The shirt sells for about $30.
Gorgonz, 877/725-4386,
www.gorgonz.com
Nice Gloves. Many modern work gloves don't
live up to their "high-performance" designation, but, based on
my experience, I think the Work Grip and Work Dexterity gloves
from Carhartt could be the exception. Gel-padded palms reduce
fatigue from high-vibration equipment, and hook-and-loop
closures ensure a snug fit. And, thankfully, the color scheme
is free of Day-Glo colors. I found these gloves on the Web for
$20 a pair. Carhartt, 800/833-3118,
www.carhartt.com
