- Q.We installed untreated
cedar shingles on the exterior walls of a vacation home
in central Maryland. Now the owners are complaining
that squirrels are eating the new siding. And the
squirrels really are eating it —
they’re not just trying to get inside the
house. Is there anything we can apply to the siding to
discourage them?
A.Bill Feist, formerly a
wood-finishes researcher with the Forest Products
Laboratory in Madison, Wis., and co-author of
Finishes for Exterior Wood, responds: There
are no cures for squirrel problems that are totally
effective in all situations, so you may have to do
some experimenting. One possible solution is to use
a “taste repellent” containing
thiram, a fungicide registered with the EPA for
general use. Repellents containing thiram at a
concentration of at least 1-to-25 have been
reported to be effective on squirrels. Another
repellent you could try is Ro-pel (508/888-0606,
squirrel-x.com),
which can be found online as well as at some garden
stores. Ro-pel gives whatever it is sprayed on a
very bitter taste, which may help curb the
squirrels’ appetite.
One of the capsaicin-based repellents used in
birdseed also might be effective. Capsaicin
— the compound found in chili peppers that
puts the “hot” in hot sauce
— has long been registered with the EPA as
an animal repellent that won’t cause
unreasonable adverse effects in people or on the
environment. Miller Hot Sauce Animal Repellent
(800/233-2040,
millerchemical.com)
contains 2.5 percent (by weight) capsaicin and is a
taste-based repellent registered for use on
ornamentals and fruit and nut trees. Squirrel Away
(squirrel-x.com),
a capsaicin-based powdered concentrate, is one of
the birdseed supplements. Check with your local
garden centers to see which capsaicin-based
products they stock — and be sure to
follow all label directions when using these (or
any other) repellents.
As a very last resort, you could try protecting
the siding with physical barriers. (For aesthetic
reasons, many homeowners won’t consider
this a realistic option.) To shield corners and
edges, apply metal drywall corner bead or staple up
4- to 8-inch-wide strips of hardware cloth bent 90
degrees. If the squirrels are concentrating on a
small area of siding, try covering it with the wire
mesh — though the squirrels will most
likely just move on to an unprotected area.
