by Tom
O'Brien
Most of us who work on old houses have a love-hate relationship
with plaster. We love it for its rock-solid character, but we
hate it when we have to patch a crack, rip out water damage, or
simply cut a hole in it.
I have never mastered the art of mixing traditional plaster and
making it stick to a wall — much less a ceiling —
but I have figured out how to fashion seamless patches using
drywall products.
The techniques I use vary according to the extent of the damage
and the location.
Determining What Can Be Saved
Hairline cracks are inevitable with plaster, but significant
plaster damage doesn't just happen; the culprit is most often a
water leak of some sort. Remodeling activities like excavation
and demolition can also inflict strains that cause cracks, even
in parts of the house not under construction.
Frequently, I'll discover serious cracks during the course of a
remodeling job that are decades old but concealed beneath a
thick layer of wallpaper. In such cases, it's important to make
absolutely sure before beginning any repairs that whatever
caused the damage is no longer a player.
If I'm looking at areas of major failure, where the keys have
broken and the crumbling plaster is literally hanging by a
thread, I start by gently prying the debris loose with a flat
bar. When I reach sound plaster, I stop, no matter how jagged
the edge. I'll come back to straighten the cut later.
After all of the loose plaster has been removed, I move on to
inspect areas where the plaster is cracked but otherwise
intact.
To make sure I don't overlook any of the cracks, I'll
thoroughly scrutinize every inch of the walls and ceilings
while holding a powerful work light at a shallow angle to the
surface. Wherever I find a crack that needs attention, I mark
it with a pencil.
Often you can't tell how bad a crack is until you cut it open.
Plaster is brutal on sharp edges, so I use two different
cutting tools for this process. First, I use a standard utility
knife, to separate the paint and the top layer of plaster (see
Figure 1). The blade gets dull fast, but a few passes across a
pocket-sized whetstone restores enough of an edge to keep
working.
Figure 1. To fashion a
strong bond between patch and plaster, it's important to widen
each crack and undercut the edges to form a key. The author
uses a replaceable utility knife blade to make the initial
incision, breaking through the paint layers and the hard, top
layer of plaster (top photos). He then employs a crack opener
from Hyde Tools to enlarge the crack and undercut the edges
(bottom photos).
After the first incision, I reach for a small hand tool called
a crack opener (www.hydetools.com, 800/872-4933) to scrape
out loose plaster and undercut the edges of the crack. A
"church key" or a painter's 5-in-1 can be equally effective,
but since the crack opener is made from high-carbon steel, it
stays sharp much longer. When it does get dull, I have a Dremel
nearby, set up with a mini-grinding wheel, to restore the
edge.
Power tools, such as a RotoZip or a minigrinder, are also
effective options for excavating plaster cracks, but they must
be used with care, because they're very messy. Also, they carve
through sound plaster almost as fast as through the damaged
stuff, so it can be hard to know where to stop. When I'm using
a hand scraper and meet up with sound plaster, I know it
instantly.
Installing Plaster Washers
Cracks that survive the scrape-out without crumbling into
chunks are filled and taped. Before breaking out the mud,
however, it's important to verify that the plaster is firmly
attached to the lath; otherwise, future cracking is
inevitable.
I apply pressure with my hands at various locations along
either side of the crack. If the wall feels the least bit
spongy, I'll use plaster washers and screws to secure the lath
and plaster tightly to the framing (Figure 2).
Figure 2. To make finishing easier, the author
countersinks the plaster washers so they're flush with the wall
surface. He uses a spade bit, stopping the drill as soon as he
makes a circle in the plaster (A). The washers get installed
with galvanized drywall screws, which will not rust and bleed
through during the mud work (B). After installing the washers,
he checks the area for any additional loose plaster
(C).
Plaster washers are designed to reattach loose but otherwise
sound plaster to the framing without causing cracks. The thin,
perforated discs flatten as the screw draws tight, but even
when fastened correctly they remain proud of the wall surface
by at least 1/16 inch. To get a flush surface, which speeds the
finishing process, I usually countersink the washers with an
expendable 11/8-inch spade bit.
First, after locating the particular studs or joists, I drill
3/32-inch pilot holes a couple of inches away from each side of
the crack. I then make the countersink hole, boring through the
paint layers but stopping the drill as soon as the bit carves a
circle into the finish coat of plaster. You don't want to drill
as deep as the brown coat, or the plaster will be too weak to
withstand the pressure from the washer.
I install the washers with 2-inch screws driven through them
firmly into the studs. The washer manufacturer, Charles Street
Supply Co. (800/382-4360,
www.charlesstsupply.com), recommends
exterior-grade screws to prevent rust bleed-through.
After fastening the plaster to the studs, I check the spaces in
between for movement. If further reinforcement is needed, I'll
fasten plaster washers to the lath alone. This time I use
11/8-inch Type S drywall screws, which are made for steel
studs; they have narrower threads, so they're less likely to
split old wood lath. Even so, this operation requires a light
touch on the screw gun.
Countersinking also becomes more challenging when there's no
framing support, because the sharp tip of a spade bit will bore
through the lath. So I use a 11/4-inch carbide hole saw (one
made for tile cutting) instead.
Mud and Mesh
When all of the washers have been fastened and the wall feels
solid, I brush or vacuum all loose debris out of the crack. I
then lightly mist the crack with water (Figure 3) to prevent
the dry plaster and lath from drawing the moisture out of the
joint compound while it's curing.
Figure 3. Application of the compound begins with a
surface misting to prevent the dry plaster and lath from
pulling moisture from the joint compound as it sets (A). By
working the setting compound (Durabond 90) from both sides, the
author completely fills the cracks. After wiping away the
excess (B), he covers the gap with fiberglass mesh tape (C,D),
then adds a second coat of compound (E). Because Durabond is
hard to sand, he is careful to wipe the surface smooth and
feather the edges.
I use a setting-type joint compound like Durabond 90 to fill
the gaps, mixing up only as much as I can apply in about an
hour. I cover the seams with fiberglass mesh tape, followed by
a second coating of Durabond. The advantage of using Durabond
is that it sets up as hard as plaster but dries quickly, so if
I'm in a hurry I can second-coat it the same day. Durabond is
almost unsandable, though, so I make sure to wipe the edges and
overlaps clean.
I use all-purpose, ready-mix joint compound for the succeeding
coats, which I apply exactly the same as I would for a drywall
job.
Drywall Fills Big Gaps
During the excavation process it's not unusual to find one or
two cracks that are worse than they appear — perhaps a
chunk of plaster on one side or the other is loose, or the
plaster's surface is riddled with a spiderweb of hairline
cracks. Places like this get the same treatment as the
crumbling sections mentioned earlier: I cut back to sound
plaster, then patch the gaps with drywall.
To avoid having to scribe a sheet of drywall to meet a jagged
edge, I'll cut a straight line through the plaster that will
remain. Once I find a place where the plaster feels solid, I
mark the cut line using a straightedge and a pencil (Figure
4).
Figure 4.
Where a chunk of plaster has come loose
but the rest of the surface is sound, one option is to fashion
a patch from drywall. The author first marks a straight line
(or a square area) in sound plaster, an inch or two away from
the damage (A). He then cuts through the plaster with a spiral
saw, leaving the underlying lath untouched (B). He removes the
loose plaster with a flat bar (C,D,E), leaving an area that can
be easily matched with a drywall scrap.
Over the years, I've tried many different methods of cutting
plaster, with results that varied from maddeningly slow to
horribly messy. The best compromise I've found is a spiral saw
equipped with a 1/4-inch plaster-cutting bit. This setup
generates plenty of dust and requires a steady hand, but it
gets the job done quickly.
Holding a vacuum hose close to the bit helps to reduce the
mess, but coveralls are a good idea and a HEPA filtered
respirator is essential. And be careful not to push the bit too
hard or it will overheat and lose its edge. A minigrinder is a
faster alternative, but it kicks up a storm of dust.
Regardless of which tool you choose, cut no deeper than the top
surface of the lath, then strip off the plaster with a flat
bar, leaving the lath strips unmolested.
Plaster thicknesses vary, so I keep an assortment of scrap
drywall on hand (1/4-inch, 3/8-inch, 1/2-inch). Using a
straightedge, I measure the gap at a variety of places around
the perimeter, then choose the appropriate board; if it's not a
perfect match, too thin is obviously better than too thick
(Figure 5).
Figure 5. Using drywall
that matches the plaster thickness (A), the author first checks
to make sure the surfaces are flush (B). He then fastens the
patch with 1 5/8-inch drywall screws, being careful to hit the
studs (C), and finishes with compound (D) and mesh tape (E) or,
in the corners, paper tape (F).
I mark the stud locations on the face of the board and fasten
it with 15/8-inch drywall screws. Wherever I have to fasten the
board to lath that's not backed up by framing, I put down a
bead of construction adhesive and use 11/8-inch Type S
screws.
After all the drywall patches are in place, the joints are
filled and taped in the same manner as the cracks. Wherever
there's a corner to be taped, however, it gets paper tape,
which is easier to fold than mesh tape.
I apply the second and third coats of mud following standard
drywall procedures. But if the patch is in a highly visible
place, I'll apply an additional skim coat of thinned joint
compound and extend it several feet onto the existing
plaster.
Covering Damage With Drywall
If a surface is riddled with cracks but isn't crumbling or
sagging, a third option is to laminate a new layer of drywall
over the old plaster. This technique works best in small rooms,
for obvious reasons. And it's much more suitable for ceilings
than walls, because the thickness of the drywall is not a
concern. I always use 1/2-inch drywall for ceilings (Figure
6).
Figure 6. Ceilings that
are extensively riddled with cracks are often best repaired by
covering the plaster with a new layer of drywall. In
preparation, the author removes existing crown by scoring the
paint line with a utility knife (A) and carefully prying up the
molding (B) so it can be reinstalled. He takes the time to mark
the ceiling joists (C), then fastens the new board with 2-inch
drywall screws (D).
Walls are more troublesome, because the drywall's thickness
noticeably reduces the profile of moldings. If you decide to
laminate over a wall surface, remove the baseboards and crown
if possible.
If you plan to reinstall the same molding, prevent collateral
damage by separating the paint lines with a sharp knife and
gently prying the moldings loose. Pry only over studs, using
the smallest pry bars that will work, and cushion their impact
on plaster surfaces with a putty knife or a wood shingle. To
prevent confusion later, I number the pieces of trim, bundle
them together, and store them in a safe place.
If you can remove the casings, and apply jamb extensions to
account for the drywall's thickness, you can cover the walls
with any thickness of drywall. Otherwise, 1/4-inch drywall is
the only option; it doesn't have a lot of meat for screws to
dig into, so I use plenty of construction adhesive and only as
many screws as needed to clamp the board tight while the
adhesive cures.
I try to fit the drywall fairly tight to the casings (1/16-inch
tolerance rather than 1/8 inch, which is the standard for
drywall). And I finish the joint by flat-taping with paper
drywall tape.
Tom O'Brien is a restoration carpenter in New Milford,
Conn.
