Skim-Coat Plaster
Continued
I use a cage mixer, which has a shearing action, to
make my mixes more consistent. I purchased a masonry hammer
drill to get the slow 900- to 1,000- rpm mixing speed specified
on the bag. For small mixes (less than one bag), I use a
plastic five-gallon bucket. For mixes of up to two bags, I use
a recycled metal lube-oil can. I get the cans free at
quick-lube garages and wipe out the residue. When working with
other plasterers, I mix larger batches in 55-gallon containers.
The wet plaster is heavy enough by itself, so I use a
lightweight magnesium hawk. When working on stilts or
staging, a helper, called a tender, will fill my hawk
with plaster using a scoop made from a capped laundry detergent
bottle with the bottom cut off.
Blister brushes -- wads of felt on a wooden handle --
are effective for removing blisters, or bumps, in the surface
caused by overworking the plaster. A blister brush can also
help get me out of trouble if a mix sets prematurely on the
surface before I have a chance to smooth it. The wet blister
brush softens the surface just enough to permit smoothing.
Cleanup.
I make tool
cleaning easy by spraying a coat of WD-40 on the backside of my
trowel, hawk, drill, mixer, and stilts before use. This keeps
the plaster from sticking. A few quick swipes with a wet
mason's brush gets the tools clean, and any plaster left to set
on a tool can be dislodged easily later on.
Good light. Shining a bright halogen light on
my plasterwork allows me to pick up imperfections that are
easily missed under dim light. Years ago, I stayed past dusk to
plaster one more wall under the low light of a couple of
incandescent lamps. When I returned the following morning, the
sun revealed small voids that weren't visible under low light.
Now, whenever possible, I work while the sun is directly on the
surface being plastered. Even at 1,000 watts, artificial light
is no match for sunlight, so on an overcast day, I use my
halogens and pay close attention to the surface.
Sizing Up the Job
At 50 to 80 pounds per bag dry weight, plaster is heavy stuff.
I stage bags by room to avoid having to move them around as the
work progresses. Coverage rates are published on the bag, but
I've developed my own "feel" for area requirements. There's a
maximum window of 30 minutes to apply the plaster and about 45
minutes to smooth it, so I plan the order of surfaces to cover
and the size of each mix accordingly. Anything requiring extra
time and attention must be considered: the number of inside and
outside corners, obstacles like electrical wires that are
hanging out for sconce lights, plumbing fittings, and places
that are too small to get at with a standard trowel.
Surface prep. On plaster resurfacing jobs,
when the wood trim is left in place, I tape the existing
casings and baseboards. To protect the floors, I cover them
with tarps or red rosin paper and roll paper over the egress
paths to the cleaning station and bathroom facilities. In new
construction, to make cleanup easy, I cover the subfloors and
protect window and door jambs with masking tape.
For reinforcement, outside wall and soffit corners receive
an expanded metal mesh bead attached with 5-penny galvanized
box nails every 8 inches. I tape all of the seams and inside
corners with self-sticking fiberglass mesh tape.
Before I mix any plaster, I run my trowel over the wall to
detect any protruding screws or nails, and then sink or remove
them. I also make sure that electrical wires are tucked into
their boxes. If the box itself protrudes from the wall, it
slows me down considerably, because I can only trowel up to it,
not over it.
Getting the Right Mix
Nothing is worse than plastering with a bad mix. For
consistently good mixes, I purchase my plaster from suppliers
who rotate their stock often. In one lumberyard, I noticed the
same pallet of plaster collecting dust for a couple of years. I
wouldn't get near that stuff -- its shelf life had long expired
and the chemical properties would have changed to the point
that mixes would not set properly. Before mixing, I make sure
that the mixer, drill, and mixing container are free from dried
plaster. If hardened chunks, known as "hitchhikers," dislodge
into the mix, I'll have to pick each one off the wall with my
finger.
| Figure
3. Plaster is highly alkaline, so it's a good
idea to wear dust protection during mixing, the
dustiest part of the job. Use cool, clean water for a
predictable mix, avoiding temperature extremes, which
affect setting time. A recycled lube container controls
the splatter of a two-bag mixing operation. |
Mixing. To mix a batch of plaster, I put cool,
fresh water in the mixing container, then my tender quickly
pours in the plaster with the mixer spinning (Figure 3). Stay
away from extreme water temperatures, because icy cold water
will cause fast setting, while hot water will cause the set to
take much too long (the opposite of what you might expect).
Manufacturers never give exact water-to-plaster ratios; for
example, USG recommends 12 to 15 quarts of water per 50-pound
bag of Diamond. Like a good chef, I've developed a feel for how
much water and plaster to mix, so I never actually measure. I
try to achieve a consistency that is something like soft-serve
ice cream. To eliminate lumps, I mix Diamond for the
manufacturer's maximum recommended time of five minutes. While
mixing, I add water or plaster to get the consistency I like --
just thick enough not to slide off my trowel when I hold it
sideways. When I plaster over Gold Bond's Kal-Kore blueboard, I
use a looser mix, because the board has stronger "suction" than
USG's Imperial board. I've come to prefer the mixed-brand
combination of Diamond plaster over Kal-Kore blueboard.
Throwing on Plaster
First, I scratch the seams. The term "scratch" refers to a
coat of plaster that is covered over by a finish coat. To
scratch the taped seams, I apply a thin, tight coat of plaster
and then fill in the outside metal corner beads. The scratched
seams can be plastered with the very next mix. Seams that are
scratched one day and plastered the next should be wetted just
before plastering to keep the scratch from sucking the moisture
out of the new plaster. I'm careful not to get the blueboard
wet, because plaster doesn't stick very well to wet
blueboard.
Troweling the field. After pouring the plaster
onto the mixing table, I use my trowel to corral the plaster
from the table onto my hawk, and move it to the center to keep
it balanced. Using the trowel, I scoop the plaster off the
hawk, tilting it slightly towards the trowel. I'm right-handed,
so I start just above the floor at the left-most corner of the
wall, spreading the plaster up and arcing to the right across
my body, as far as I can comfortably reach. Then, without
letting the trowel leave the wall, I press the plaster backward
in a downward sweep with the opposite edge of the trowel. I
finish with a light upsweep to erase the lagging trowel line
(Figure 4).
Figure
4. After scratching the panel seams, the author
applies plaster in arcs, sweeping up to spread, down to
embed, and back up to erase the trowel mark. The trowel
never leaves the surface during
application. | |
