Skim-Coat Plaster
Continued
Joint-compound tapers apply mud in straight up-and-down or
side-to-side motions, whereas plasterers always trowel in arcs.
I keep my wrist stiff and put my whole body into the troweling
motion. Each pass is the same up-down-up motion, erasing the
lagging trowel line as I go. After I reach the planned stopping
point, I get on the stilts and again go left to right, arcing
downward across my body. With each pass, I carefully place the
trowel into the ceiling-wall corner, pulling it down to blend
it into the plaster below. I feather the wetter plaster above
into the somewhat stiffer, setting plaster below, taking care
not to press the trowel too hard into the surface. I don't want
to "pull" the plaster and disturb the set. Before reloading the
hawk, I clean the back edges of my trowel -- every time.
Scratch and Double Back
The entire one-coat application is actually done in two steps,
called scratch and double back (sometimes
referred to as greasing). The application just described
is the scratch (not to be confused with the previous step,
scratching the seams). Once I'm done with the scratch, I double
back over the wall in the same way, adding more plaster from
the same mix, filling in with lighter trowel loads. The goal is
to achieve an even 3/32-inch-thick cover of plaster over the
entire surface. The scratch and double-back steps should not be
confused with a true two-coat system, which I'll describe
briefly later. I always plaster the larger areas first, so the
mix on the table gradually stiffens as I'm scratching and
doubling back. Usually, if there's any mix left after doubling
back, it will be too stiff to scratch-coat any more surface.
However, once the mix stiffens to the consistency of hard ice
cream, it's perfect for filling in corner beads.
Inside corners. I plaster inside corners in
one of two ways. The first is to fill a wet corner when
plastering adjacent surfaces. I'll run a corner trowel from top
to bottom, or left to right, and finish with a short stroke
from the opposite direction. The second method is to pull the
corner on one side only, by placing a full trowel into the
corner and pulling the plaster a short distance out across the
surface. The adjacent side is left uncovered during that
particular mix, and pulled separately later.
Smoothing. After the scratch and double back,
the next step is smoothing. Using a pressurized water
container, I spray on a fine mist and trowel it in to smooth
the plaster and fill any voids. To achieve a crisp line on a
pulled corner, I run a wet, angled sash brush lightly from top
to bottom just before troweling. For a wet corner, I run a
clean, wet butterfly down the seam.
Polishing. An hour or so after application,
the plaster turns a light brown color, which indicates that
it's ready for polishing. I polish with a dry trowel, pressing
the trowel hard and nearly flat to the surface. Polishing gives
the wall a satin-like finish. If, while I'm polishing, I notice
any tiny voids, I spray the area with a light mist of water and
trowel in a bit of ready-mix joint compound. It works like
magic, no sanding required. During the day or two after
"browning," the plaster lightens to a bright white.
Different Mix, Different
Tricks
The process I just described is how I plaster using Diamond.
For each plaster product, there are differences in the method:
For instance, when plastering with Uni-Kal, I polish the
surface by running a damp blister brush over it, followed by
the trowel. This draws the finer plaster particles to the
surface. Troweling drives them into the surface, producing a
mirror-like finish (Figure 5).
Figure
5. After the initial set, or "browning," the
plaster can be polished, using water to bring up the
fines and a trowel to burnish them into the surface.
It's possible to achieve a mirror-like finish with this
method. |
There are a few rules I set for myself, no matter what I'm
plastering with. I apply the plaster mix "tight," firmly
pressing it into the wall, thin and even. If it pulls with the
trowel, I leave it alone so as not to refracture the plaster as
it is setting. Refracturing disturbs the set, causing a longer
wait before finishing. By applying plaster in thin coats, I
never knock down high spots. I'm always adding, not taking
away. This ensures that I never refracture the plaster. The
less I run my trowel over the surface to get it right, the
better the finished product, and the less fatigued I
become.
Other Types of Plastering
I do a lot of resurfacing work and am often called on to
repair crumbling and deteriorating plaster surfaces. Many of
the homes in my area have old "horsehair" plaster over wooden
lath, some more than 200 years old. If the old plaster is
coming down in sheets, I remove it completely, along with the
wood lath. This is the most expensive approach, because I
usually have to sister in new framing, strap the ceiling joists
using a laser for reference, and get everything straight before
putting up the blueboard. If the old plaster is cracked but not
loosened from the wood lath, I tape the cracks with self-stick
fiberglass tape. Then I apply a water-based plaster-bonding
agent, such as USG's Plaster Bonder, over the entire surface,
and follow up with a two-coat plaster system. The plaster
bonder, also called liquid lath, can be plastered over about an
hour after application. I've used this process over stucco
textures to make walls smooth for wallpaper. It's a good idea
to apply a bonding agent to blueboard that has faded from
exposure to ultraviolet light, and also before blending new
veneer into existing sanded drywall or old plaster (Figure
6).
Figure
6. For a two-coat veneer over old plaster or
drywall surfaces, an orange-colored acrylic bonding
agent provides surface grip for the gray coat. The
author also coats the facing to restore the bond on
blueboard faded from UV-exposure. A 42-inch "slicker"
distributes the plaster base coat evenly, eliminating
irregularities. | |
Two-coat systems employ a base coat, or gray
coat, and are useful for refinishing irregular surfaces. The
base coat is applied with the same scratch and double-back
steps as the veneer plaster. When applying a two-coat veneer,
however, there's no need to scratch the seams to get good
results. The base coat has coarse aggregates, which should not
be fine-smoothed, because they provide the "teeth" to hold the
topcoat veneer. There are two special plastering tools that I
use to straighten a base coat. One is a magnesium darby, a 36 x
5 1/2-inch bar in the shape of a piece of beveled siding. The
second is a magnesium slicker, a 42-inch-long tool similar to
the darby, but a bit stiffer because it has a bent edge. I use
either one to straighten the base coat once it starts to set,
by scraping the tool edge over the entire surface.
Sam Singer
is a plasterer and
finish carpenter working out of Uncasville, Conn.
