- Q.I am remodeling a large,
older home that is heated by a low-pressure steam
system. Because of the size of the house, steam seems
to be a good system to use, but the boiler is obsolete.
We are adding insulation and sealed double glazing. How
can I calculate the required size of the new boiler? Or
can the system be converted to hot water?
A. In a steam system, the
boiler is not sized according to the calculated
heat loss of the building. Instead, it must be
sized according to the number of square feet of
installed radiation. Tables that give the
equivalent square feet of radiation are available
for most old radiators from the Hydronics Institute
(P.O. Box 219, Berkeley Heights, NJ 07922;
908/464-8200). A new radiator should include that
size in the specs. Steam boilers normally carry a
specification plate that gives the number of square
feet of radiation the boiler can supply.
If the boiler is sized according to the
calculated heat load, it will not supply enough
steam to reach the far end of the system without
condensing first, and the system will never work
properly. This is a common problem when conversion
burners (gas or oil) are installed in old
coal-fired boilers. The burner must be large enough
to generate the same amount of steam as the
coal-fired unit, and that is often two or three
times as large as the burner size derived from the
calculated heat loss. A steam system which is
underfired can have an efficiency approaching zero,
regardless of the reported efficiency of the
boiler.
If the house has a two-pipe steam system, as
opposed to a one-pipe system, it can be converted
to a pumped hot water (hydronic) system with minor
changes in the piping (removing the steam traps and
the Hartford loop). You can then use the same
radiators. The hydronic systems will produce a more
even heat, especially if the system temperature is
controlled to match outdoor temperatures. By
contrast, a steam radiator is either on or off. For
more information on converting steam systems to
hydronic, contact the Hydronics Institute.
