2004 International Builders’ Show
Product Highlights
Tremco Barrier Solutions. Designed to protect the above-grade area between the foundation footer and sill plate, the above-grade system’s three components are applied alone or in combination to the exterior of foundations. A waterproofing membrane, an insulation board, and a textured, water-repelling topcoat make up the system. (800) 379-2768. www.guaranteeddrybasements.com.
Senco. The RoofPro 450 (shown) and RoofPro 455 coil nailers feature lightweight designs, adjustable depth of drive, and handy shingle guides. Each is built around aluminum main housings that will stand up to hard use, the maker says. Steel wearplates help reduce the effects of shingle abrasion. (800) 543-4596. www.senco.com.
JennAir. Because of a third rack, this dishwasher offers 20% more usable capacity. The third rack is positioned next to the bottom wash arm for the strongest wash. It has four wash levels, hard food disposer, stainless steel tub, and a towel-bar handle. (800) 536-6247. www.jennair.com.
Bosch Power Tools. The 6-pound 1590 Jigsaw resists stalling in hard materials and features the Precision Control Blade Guide System, which eliminates blade wander. Constant Response Circuitry provides a soft start, and the tool has a variable speed of 500 up to 2,800 SPM for soft to hard materials. The One-Touch Blade Change System provides one-handed insertion and lever blade ejection. The saw has a 6.5 AMP motor. (877) 267-2499. www.boschtools.com.
Style Solutions. The Structural Porch Post is a load-bearing column that can support up to 12,000 pounds. The steel-reinforced column is surrounded by polyurethane and has a square profile. Intended for exterior use, the post resists splintering, decaying, insect infestation, and water penetration and absorption. (800) 446-3040. www.stylesolutionsinc.com.
Cedar Valley. Measuring 1/2-inch thick, the kiln-dried Western Red Cedar Coastal Panel comes in 8-foot shingle panels available in either mixed or vertical grain shingles in one and two courses. The panels have concealed nailing patterns and 1/8-inch open keyways and are certified to withstand winds up to 196 mph. An Elk VersaShield UV-protected moisture barrier is included. A variety of colors, finishes, and design options are available. (800) 521-9523. www.cedar-valley.com.
G.E. Monogram undercounter refrigerator modules fit standard 24-inch cutouts. Products include the Wine Reserve, which stores up to 57 wine bottles; the Beverage Center, which houses 12 wine bottles and up to 126 12-ounce cans; the Drawer refrigerator with top and bottom drawers; the Outdoor/Indoor unit; the Bar refrigerator; and the Gourmet unit with shelves that convert to removable serving trays. (800) 626-2000. www.geappliances.com.
Sterling. An above-floor-drain (AFD) option is available on most Acclaim, Ensemble, and Performa bath/shower alcove shells. The feature eliminates the need to cut into subflooring for drain assembly and for constructing a separate cradle for under-support. (800) 783-7546. www.sterlingplumbing.com.
Arch Wood Protection. Suited for sill plate and interior applications, SillBor borate-treated wood features SBX, a preservative that makes the wood resistant to insects and fungal decay. The borate is forced into the wood under pressure. (770) 801-6600. www.wolmanizedwood.com/sillbor.htm.
Hy-Lite. Prefabricated real glass block fixed windows are available in six stock sizes and feature white silicone caulk lines for a true mortared glass block look. The windows are certified by NFRC, AAMA, and ANSI, and interior and exterior sides are sealed to prevent water penetration from either side. Vinyl spacers between the glass blocks keep them perfectly aligned within the thermally broken aluminum frames, the maker says. (877) 712-4013. www.hy-lite.com.
Vetter Windows & Doors. The Raised Panel Wood Hinged Patio Door is available with single or double panels above the door’s foot rail. Both the interior and exterior of the panels have a raised profile. The patio door is available in clear natural pine, oak, cherry, maple, or mahogany and comes either primed for painting or aluminum-clad on the exterior and ready to stain, seal, or paint on the interior. Seven standard and 48 custom clad exterior finishes are available. (800) 838-8372. www.vetterwindows.com.
For more product information, visit ebuild, Hanley Wood’s interactive product catalog.
