Commercial
Estimating Pitfalls
How to approach estimating so that errors don't happen.
7 MIN READ
Dan Drabek
Dan Drabek
Estimating combines science and art. The science part is straightforward enough: The prints show the square footage or linear footage for some item, so you do a takeoff and that’s how much you budget for.
The art involves looking at a set of prints and recognizing the intangibles that aren’t spelled out.
The Golden Rule
I have an old estimating manual that contains something called the Golden Rule of Estimating, which says, “Consider not only the cubic foot, cubic yard, linear foot, square foot, pound, or ton, but all of the complicating conditions encountered in putting the material in place.”
Sure, the language sounds dated, but it’s great advice, and the principle holds true for any project ever estimated.
In this article I will look at some typical estimating pitfalls that contractors are prone to. Most of the examples come from remodeling projects, but the same issues apply to new construction. The point is to get you thinking about how to approach estimating so that errors don’t happen. Deriving quantities is easy; it’s the thinking behind the pricing process that can make or break your profits.
Excavation
When looking at the plans for an addition, it’s tempting to take off the square footage of the new room, multiply by the depth of the foundation, add for overcutting or sloping the excavation, and then call it good. But if you did not consider the configuration of the site, you missed something.
Site access. Can the excavator’s equipment get into the backyard without damaging the driveway, destroying trees, or ripping down the electrical service? Is there room for the machine to maneuver once it gets there? Can dump trucks be backed into the yard without crushing the septic system or getting so close to the foundation that they collapse the basement wall? The site conditions may require you to use smaller equipment, protect parts of the yard, or shuttle excavated soil out to the street before loading it into trucks.
All of these possible complications point to additional expenses that will be yours to bear if you don’t account for them in the original estimate. It’s also important to qualify your bid to exclude things you can’t see or could not reasonably be expected to anticipate. You may want to put various qualifications in the contract, such as a requirement providing for reasonable access to the site and a disclaimer of liability for damage to tree-root systems, buried sprinkler lines, and the like.
Storage space. Assuming you can get the digging machine into the yard and the excess dirt out, is there room to stockpile material for use as backfill when the foundation is completed? If not, you’d better include money for importing material, which at $10 to $15 per cubic yard can quickly add up to several thousand dollars on a big addition. Plus you’ve got to pay to haul off the material you originally planned to use for backfill.
Concrete
The access issues described above apply to concrete as well. If you can’t get the trucks into the backyard, have you accounted for the man-hours required to wheelbarrow the mud from the street? If there’s a lot of concrete and the pour is far enough from the street, you may want to rent a pump. In this area, a concrete pump rents for $600 to $800 per day, but that’s a bargain compared with the labor cost of moving it by hand (not to mention that the workers who haul it will be shot for the rest of the day).
Wasted material. If you don’t use a pump, be sure to factor in additional concrete, because some of it is going to get spilled on the way to the foundation or splattered down the side of the trench when the wheelbarrows get dumped.
Once the concrete is placed, the truck driver will want to wash out the chute. If the part of the yard near the street is landscaped, you may be hard-pressed to provide a washout area. It’s illegal to wash this stuff down the storm drain, so you’ll need to come up with some other way to dispose of it. The same goes for concrete pumps — there’s often a fair amount of material left in the hose.
Rounding quantities. When calculating concrete quantities, keep your numbers in cubic footage, then round up to the next highest cubic yard by phase. If you round each individual section of footing to cubic yards, you may end up buying more concrete than you need. Of course, that’s better than estimating low and having to pay a “short load” charge when you come up half a yard short.
Tie-ins to Existing
Whether it’s siding, roofing, or even hardwood floors, quantifying just the “new” areas of material will leave you far short in material and labor. Any of these materials will need to be stripped back cleanly into the existing to ensure that new and old match. The labor to remove clapboards or hardwood flooring to tooth the new and old together, and then reassemble it all so the transition isn’t noticeable, can easily cost more than the installation labor for the entire new area. With flooring, you may have to sand and refinish half the hardwood floors in the house to get to a clean breaking point.
Explaining a higher price. Since carrying this extra work will bump up your bid, you need to tell the customer what you are including and why: “Mr. and Mrs. Jones, the other contractors you’re talking to may plan to paint only the new siding. My bid includes repainting the entire side of your house, because otherwise the siding’s not going to match. There are some other items like this in my bid as well. So, if my price is higher, it may be because I plan to do more than the bare minimum in order to provide you with a proper job.”
Breaking down the process. Tie-ins usually eat up time and material. If you’re opening up an existing structure, you’ll have to consider the need for shoring and temporary walls. This may require painstakingly selective demo and a lot of shimming to get everything to blend. To plan for this, break the process down into individual steps, assigning labor and materials to each, and then total the whole thing. The number will probably seem high, but odds are you’ll need every penny of it.
Carpet and Tile
One issue regarding flooring has to do with what size pieces the material comes in. If you need to carpet a 12-foot-by-12-foot room, you can price 16 square yards of carpet and install a single 12-foot-by-12-foot piece. If, however, the room measures 13 feet by 13 feet (mathematically 18.8 square yards), there will probably have to be a seam, because most carpet comes in 12-foot widths.
Assuming you can turn the carpet 90 degrees for seaming, you could buy a 15-foot length and use the offcuts to piece on an extra foot of width. But since some carpet has a direction to it, you might have to order a second 12-foot-by-13-foot piece to get the missing 1-foot-by-13-foot strip. The total could be as much as 35 square yards, which even at $20 per square yard adds $340 to your material costs.
Of course, you can always buy 15-foot-wide carpet (available only in certain lines, and at a higher cost), or hope that the flooring installer will cut you a break and use the leftover carpet for a remnant.
The same principle applies to tile flooring. If the room is 10 feet square and the tile is 12 inches square, you’d simply order 100 square feet of tile, plus a few extra pieces in case some break. If, however, the room is 10′-2″ x 10′-2″, you’ve got to order a minimum of 10 square feet of additional tile (assuming you can get two cuts from each tile). This is not a big deal with $3-per-square-foot ceramic tile, but it is if you are buying $22-per-square-foot travertine.
Protecting Existing Surfaces
One item I rarely see on contractors’ estimates is a cost for protecting existing surfaces. The added expense of covering floors with Masonite and plastic sheeting may seem high — but not if you compare it with the price of having to refinish the hardwood. As many of you know, getting drywall dust out of the cracks between hardwood floorboards isn’t fun, and it’s a job that can easily be avoided.
I have a category in my estimates called General Requirements, which covers such items as scaffolding, rental equipment, trash cans, brooms, and all the other stuff every job seems to require. There are a number of items in that section for protection — plastic, Masonite, tarps, walk-off pads, self-adhesive carpet protection, and so on. To compile the estimate for these items, I plan access routes through the house and across the site, and identify any items that require special protection.
Bob Kovacs
Bob Kovacs, based in Canton, Ga., has more than 25 years of experience managing and estimating residential and commercial construction projects.
