First Look: Algae-Resistant Shingles; Massage Tub; and more
Bosch Power Tools and Accessories. Organized by a color coded labeling system, the new family of abrasives for grinding, finishing, and blending comprises more than 80 wheels that balance cut rate and wheel life. Flap discs, offered as start-to-finish abrasives, are also included. The discs allow rapid stock removal without blade changes and improved consistency of finish. (877) 267-2499. www.thomasvillelighting.com.
Mitten. The maker has improved its 51/2-inch Traditional Style vinyl corner post by adding a foam backer insert that is treated to repel insects and also provides impact resistance. The fluted corner trim has a wide profile and comes in a 20-foot length. The posts are available in 18 low-gloss colors. (800) 265-0774. www.mittenvinyl.com.
Atlas Roofing. The Stratford Shingle has been reformulated with the addition of an algae-resistant treatment. Available in nine colors, the heavy-weight architectural shingle features a granule overlay that provides a dimensional appearance, and the maker’s Speed-Lap End Cut allows quick and easy installation. (770) 933-4479. www.atlasroofing.com.
CMI. Made from a wood composite material that is easy to cut, machine, and nail, MiraTEC Treated Exterior Composite Trim is now available in a 16-inch-wide, 5/4-thick (1-inch actual) board. The trim board is factory primed on four sides and features a cedar texture on one flat side and a smooth finish on the other. (800) 255-0785. www.miratectrim.com.
Alside. A one-piece corner post that provides the detail of a three-piece system and features a foam backing insert has been added to the Trimworks line of decorative accents. Also available in 3- and 5-inch lineals, custom crown and soffit moldings, and outside corner posts, the line now comes in 19 colors. (800) 922-6009. www.alside.com.
Simonton Windows. Available on most Simonton Impressions 9800 windows, UV-resistant Exterior Painted Coatings in hunter green, bronze, chocolate brown, and stone resist fading, the maker says. (800) 746-6686. www.simonton.com.
Clarke Products. Offering component adjustments including water pressure and variable massage, Total Massage bathtubs are equipped with both whirlpool massage jets and bubbling air-massage jets. (972) 660-1992. www.clarkeproducts.com.
Royal Mouldings. Part of the No Rot line, Trimplank cellular PVC interior and exterior trim boards come in smooth, embossed wood grain and stucco surface textures in lengths up to 18 feet. The trim boards can be cut, nailed, mitered, and routed with woodworking tools and resist warping, twisting, splintering, and rotting. The trim boards come in a factory-applied bright-white finish. (800) 368-3117. www.royalmouldings.com.
Wellcraft. The 5600 Series Modular Egress Window Well System is designed with built-in ladder/steps to provide below-grade living spaces with a means of escape and meets International Residential Code 2000 egress requirements. Constructed from high-density polyethylene, the modular system features a snap-together design and stackable pieces that allow window-well depths to fit any window height. (888) 812-9545. www.wellcraftwells.com.
