First Look: Custom Built Railing, Products and more
The newest products for the remodeling market
Maine Ornamental.
Offering a custom-built railing look in just minutes, Pre-assembled Railings are made entirely of cedar and can accommodate the maker’s glass rail accents. Packaged in fully assembled sections complete with hardware, installation requires setting the posts and attaching the sections using the supplied brackets. Measuring 34 inches high, the railing is available in 6- or 8-foot sections. Matching cedar post sleeves and 6-foot stair rails are also available.
866.780.3507.
www.postcaps.com.
Western Wood Products.
For improved installation, performance, and appearance, Brigade Board features a patent-pending fastening method attaching vinyl siding to high-density foam insulation with rivets. Contoured to the vinyl, the rivets let the siding float freely from the insulation and adjust to climate changes. The EPS foam backing creates a uniform exterior surface and offers an R-value up to 3, the maker says. Available in 16 colors, Brigade Board comes in traditional clapboard and Dutch lap profiles, with new profiles forthcoming.
800.476.3122.
www.westernwoodproducts.com.
Symmons.
Equipped with self-adjusting infrared microchip technology, the Ultra-Sense S-6050 Series Sensor-activated Faucet allows for hands-free operation. The faucet is available in single-hole or 4-inch center installation styles. A 6-volt lithium-ion battery powers the unit and lasts for approximately 180,000 cycles.
800.796.6667.
www.symmons.com.
Hyde.
The Dual-action Flex Roller allows painters to finish more quickly with a single coat of paint. To paint in one pass, place the top roller on the wall, and let the frame’s flexible spring action force the bottom roller to follow for extra coverage. Designed for use with extension poles, standard 9-inch roller covers, and a deep-well paint tray.
800.872.4933.
www.hydetools.com.
MNG Hardware.
The nature-inspired Vine collection features a subtle vine pattern that winds its way around a wide selection of cabinetry hardware. Round and egg-shaped knobs are joined in the collection by 3- and 4-inch tubular drawer pulls. Oversized pulls measuring 13 1/2 inches long and 1 inch in diameter with a 2 1/8-inch projection are also available, though additional lead time is recommended. Look for Vine in satin silver, satin brass, and oil-rubbed bronze finishes.
877.598.8889.
www.mnghardware.com.
E.L. Mustee & Sons.
Give a home the convenience of another shower with the free-standing Durastall Shower. The square stall is available in 30-, 32-, or 36-inch sizes, for easy installation in confined spaces. Components include a shower valve, curtain, safety railing with a molded-in soap dish, and shampoo container. A drain is included in the slip-resistant floor. Multiple base options are available. Aluminum-frame shower doors have a chrome finish and can be made of obscured tempered safety glass or a crystal styrene panel.
216.267.3100.
www.mustee.com.
Petzl.
Combine jobsite safety and convenience with the Tikka XP Hazloc headlamp’s hands-free lighting. Featuring one beam for distance and one for up-close lighting, the durable, water-resistant lamp has a lightweight body mounted on an elastic headband. A signal warns when the battery-operated LED lights are 70% and 90% exhausted. An operational strobe is useful in emergencies. Optional hardhat mount is available.
801.926.1500.
www.petzl.com.
Battic Door.
Constructed of expanded polystyrene foam that provides an R-value of 42, the E-Z Hatch Attic Access Door System provides sealed, energy-efficient attic access that installs into the ceiling in minutes, the maker says. Suitable for new construction or retrofit, the E-Z Hatch measures 22 inches by 30 inches, and exceeds all building code guidelines, including new Energy Star Thermal Bypass requirements. Use with any insulation, including blown-in.
508.320.9082.
www.batticdoor.com. For more product information, visit ebuild.com, Hanley Wood’s interactive product catalog.
Lauren Hunter
