First Look: Faucets; Water Heater; Washer/Dryer; and more
Whirlpool.
The Duet Steam washer and dryer pair naturally steams out stains, wrinkles, and odors in minutes without pre-treating or chemicals, according to the manufacturer. Shown in aspen green, the washer uses up to 73% less water and 77% less energy compared with conventional top-loaders, the maker says, and steams away tough stains, from grass to grease.
800.253.1301.
www.insideadvantage.com.
Moen.
A trend toward cottage-style design moves into the bath with the new Rothbury collection. The vintage design incorporates classic masculine lines with low-arc spouts. The collection includes two-handle center-set and widespread faucets, a Roman tub faucet with three- or four-hole diverter options, shower options, and a suite of complementary bath accessories. It also is the first Moen collection to offer a water-saving aerator with a 1.5 gpm flow rate, compared with traditional aerators that flow at 2.2 gpm.
800.289.6636.
www.moen.com.
Rinnai.
In a new approach to efficient home heating, the Tankless Heating System (THS) combines a tankless hot water heater with a hydronic air handler to deliver on-demand heat using the same source for both domestic hot water and space heating. For optimum heat output, a custom-designed pump maintains constant flow during operation, while a priority system temporarily stops the air handler during periods of high hot-water demand, preventing the unit from blowing cold air. Suitable for up-flow, down-flow, or horizontal left/right orientations. Available accessories include a programmable thermostat, mixing valve, and side-mount filter rack.
800.621.9419.
www.foreverhotwater.com.
Dow Building Solutions.
As a three-in-one structural insulated sheathing, Styrofoam SIS provides structural bracing, insulation, and weather barrier protection. Its R-values range from 3 to 5.5, and the sheathing helps reduce energy consumption, thereby lowering energy bills, the maker says.
866.583.2583.
www.dow.com.
ORG.
The Easy Track storage system lends structure to any wardrobe. Maximize wall space with corner shelves and customize the design with cabinets, drawers, rails, and more. Products from the line come in a choice of four solid colors and five woodgrain finishes. Custom organization solutions are available.
800.562.4257.
www.easytrack.com.
Eldorado Stone.
RoughCut stone veneer mimics limestone with embedded, fossilized artifacts and a cleaved face. It comes in three colors and with stone sizes from 1½ inches to 11 inches wide and from 2 inches to 18 inches long.
800.925.1491.
www.eldoradostone.com.
RotoZip.
Designed by drywallers, for drywallers, the DR1 drywall router measures just 7½ inches long, weighs 2.8 pounds, and features a smaller grip diameter than similar tools, for enhanced control and minimized user fatigue. At 33,000 rpm, a 6-amp motor delivers up to 45% higher speeds under load than other models, the maker says. Other features include an on-tool wrench-storage compartment, replaceable motor brushes, a redesigned depth guide, and a durable, hardened-steel lock pin encased in solid aluminum to protect the shaft lock.
877.768.6947.
www.rotozip.com.
Eagle Window & Door.
The Axiom retractable screen fits with the maker’s Axiom casement and awning windows. Screens are housed on the inside of the window frame when not in use and come in 9 wood species and 11 interior finishes. The screen automatically regulates the speed at which it retracts, so it will not cause damage or be damaged by an accidental release.
800.324.5354.
www.eaglewindow.com. For more product information, visit ebuild.com, Hanley Wood’s interactive product catalog.
