Introduction to Critical Path
"With CPM, you’ll know when each task must be started and finished to complete the job on schedule"
Simple construction projects rarely have formalized schedules. But as projects increase in size and complexity, involving more labor, materials, and equipment, you may need a scheduling technique that will give both you and the owner a better picture of a job’s progress. A good scheduling system gives you several benefits. One is that you can get a good financial picture of the project. Both your costs and the owner’s are closely related to a project’s duration. The sooner a project is completed, the sooner the owner can use the building, and the sooner you, as builder, can direct your resources to other jobs. In addition, a good scheduling system: • establishes critical “must-do” dates and other milestones, such as start and finish
