New products for remodeling
The newest products for the remodeling market
Tamko. Combining the strength of steel with energy-saving technology, MetalWorks Cool Colors shingles offer aesthetics and performance for a wide range of applications. Manufactured to be long-lasting and offer a high solar reflectance, the product is rated by the Cool Roof Rating Council as having initial solar reflectance of up to 0.34 and initial thermal emmitance of up to 0.87. A variety of styles and colors are available. 800.641.4691. www.tamko.com.
Devcon. For a strong hold when bonding plastics, metals, fiberglass, wood, and more, try Plastic Welder II. Requiring little or no surface preparation, the two-part methacrylate adhesive will not run or drip when used on vertical surfaces, the maker says. Attaining a functional cure in three hours, its load-bearing bonds acclimate to temperatures from 250° F to -40° F. Weight and stress are distributed across the entire length of the bead, rather than concentrating in specific areas as with mechanical fasteners, the maker says. Several colors and packaging options are available. 978.777.1100. www.devcon.com.
Pergo. For the look of ceramic and stone tile without the hassles of chips and cracks, try Accolade laminate tiles. Six available styles feature a realistic stone look and feel thanks to advanced texturing technology. Like the maker’s wood-look floors, installation is as straightforward as clicking tiles into place. Moisture protection makes the tiles ideal for kitchens, bathrooms, mudrooms, and elsewhere in the home. 800.337.3746. www.pergo.com.
RotoZip. The XShield guard attachment converts any current RotoZip Spiral Saw into an ultra-compact circular and flush-cut saw. The attachment includes a pivoting die-cast aluminum foot for stability and quick blade adjustments up to ¾-inch deep. A removable cover converts the tool from circular saw to flush-cut. Compatible wheel accessories include the Wood Cutting XWheel for laminate flooring, OSB, paneling, and more, and the Tile XWheel for porcelain, granite, glass, ceramic, and marble. Both dome-shaped wheels measure 4 inches in diameter. 877.768.6947. www.rotozip.com.
Oceanside Glasstile. Mimicking color and texture variations found in geological rock formations, hand-cast Geologie tiles feature a mix of matte and reflective finishes with smooth and textured surfaces for sophistication and drama. Twelve color blends and five pattern options are available with nature-inspired colorways including Black Hills, high desert, sand dune, and Painted Desert. All blends come in 1-inch-square mosaic tiles, with six blends also available in the maker’s 1-inch-by-2-inch offset, random modular, merge, and lattice patterns. Custom blends are also available. Visit the Web site to find a showroom in your area. www.glasstile.com.
NuHeat. For use with the maker’s radiant floor-warming systems, the Harmony thermostat has a distinctive, decorative design, and several designer-inspired features. The programmable unit can be flush-mounted behind any double-gang decora-style faceplate, allowing it to blend in with the room design. Energy Star-rated and available in 110- and 200-volt formats, Harmony features programmable seven-day settings to let homeowners use their floor-warming system efficiently. 800.778.9276. www.nuheat.com.
Turnstyle Designs. The maker’s newest architectural door and furniture handles encapsulate fabrics, wallpapers, or other materials in crystal-clear acrylic. The U.K.-based manufacturer maintains a stock of six diverse fabrics, and custom orders can be produced subject to minimum orders and compatibility. The option lets designers marry hardware with curtains, wallpaper, and soft furnishings. Visit the Web site to find a U.S. dealer near you. www.turnstyledesigns.com.
Ryobi. Improving on previous versions, the model BTS21 10-inch portable table saw offers new features, including a larger rip capacity, and sliding miter table with built-in miter gauge. Easy to transport and store when not in use, the unit features a cord wrap; convenient on-board blade, wrench, and rip-fence storage; and a fold-up stand. The 15-amp motor powers through a wide variety of cuts while a 2½-inch dust port and dust bag keep the work area clean. Forthcoming accessories include beginner and intermediate router tables. 800.825.2579. www.ryobitools.com.
Lauren Hunter
