Products for the remodeling market
The newest products for the remodeling market
Hettich America. For strategic placement within closets and cabinets, the Lite-inside system allows for built-in LED lighting to shine a spotlight on usually dark spaces. The illuminated garment/coat rail (shown) is one element of the line, and separate shelves can be assembled with the lighting system so each is individually illuminated. The battery-operated LEDs include a sensor that automatically switches the lights on when the door opens. The lights turn off on their own after a short time. 800.438.8424. www.hettichamerica.com.
Ridgid. Get a grip on plumbing installations with the Multipurpose Faucet & Sink Installer. The open slot design allows the tool to be used over water supply lines so mounting nuts can be tightened or removed without disconnecting supply lines. Aluminum accessories include a shut-off valve attachment to turn hard-to-reach angle stops without marring the chrome. A hex socket attachment fits 3/4- and 1-inch hex nuts and plastic supply-line nuts, and a strainer basket attachment holds drain units in place while tightening the mounting nut. 800.769.7743. www.ridgid.com.
Timberland Pro. Stay productive even in extreme cold with Thermal Force work boots. The boot’s heat-retention system uses insulating technology to protect specific areas of the foot, including the toe and the top of the foot. To keep from adding bulk, thin SympaTex Reflexion membrane reflects body heat back to the foot, and 3M’s Thinsulate insulation offers thin layers of insulation where needed. A more rugged outsole combats freezing and stiffening in severe temperatures. 888.802.9947. www.timberlandpro.com.
Pegasus. The granite kitchen sink’s oversized bowl actually helps create more workspace in the kitchen. Measuring 33 inches long, 22 inches wide, and 9 inches deep, the sink comes complete with a cutting board and colander that ride above the bowl and out of the way of the faucet to create a convenient prep area. A matching bar sink completes the look. Both sinks are available at The Home Depot. 888.809.8989. www.pegasusinfo.com.
Finley Products. The Plan Station lets building professionals take their desks with them to the jobsite. Made of durable ballistic nylon, the foldable unit provides a 2-foot-by-4-foot workspace that easily hangs from a wall, or can be used freestanding. Two pieces of user-supplied plywood give the unit structure. Multiple storage pockets hold documents, office supplies, cell phones, and more. 888.626.5301. www.planstation.biz.
Gerbing.Battery-operated heated gloves feature the maker’s new Core Heat Transfer System, which provides heat to the hands and fingers. With this system, the entire length of each finger is heated, as well as the back of the hand. Each glove is powered by a 7.4-volt lithium battery pack housed in a zippered pocket on the cuff. The battery incorporates a thermostat so users can regulate the temperature between 85° F and 135° F for up to 12 hours. 800.646.5916. www.gerbing.com.
Boss Products. Available in more than 200 colors, Boss Colors silicone sealant is a VOC-compliant, one-part sealant formulated for the siding and window markets. Offering primerless adhesion to vinyl, wood, aluminum, brick, concrete, and fiber-cement, the tinted sealant has been cross-matched to major window and siding manufacturers’ colors for a seamless appearance, the maker says. Use as a perimeter weather seal or backbedding compound. Boss Colors begins to cure within 20 minutes and resists cold, rain, ozone, heat, and sunlight. 800.928.2677. www.bossproducts.com.
Lista. Bring parts, tools, and supplies directly to the jobsite with Mobile MRO Workstations. Available in a variety of sizes and configurations to meet specific users’ needs, the units feature built-in shelf storage behind a lockable door, and full-extension drawers. Work-surface options include butcher block and galvanized steel. Drawers can be outfitted with an array of dividers for customized storage. Each drawer features the PrevenTip one-drawer-at-a-time safety system to prevent accidental tipping. Locking handles and ball-bearing casters with wheel brakes ensure safety and security. 800.722.3020. www.listaintl.com.
