Stucco Products
By REMODELING Magazine Staff. Senergy. The new One-Coat Stucco System is a pre-blended mix to which sand and water are added on the jobsite. A fiber-reinforced hard-coat stucco, the product resists fading, cracking, and abrasion, and reduces efflorescence, says the manufacturer. Used with the company’s Primer and weather-resistant acrylic, silicone, or elastomeric finishes, the mix provides long-term durability. (800) 589-1336. www.senergyeifs.com.
Stuc-O-Flex International. Europlast is a wet-mix polymer-based stucco finish for interior or exterior applications. The decorative coating offers a wide range of color and texture combinations and, says the manufacturer, gives walls the look of Old-World Venetian plaster. It may be applied to most properly prepared wall surfaces using either a trowel or a spray applicator. (425) 885-5085. www.stucoflex.com.
Stucco Creativa. A full line of plasters and stuccoes by Italian manufacturer Rivedil is available through the company. All are lime-based, non-toxic, and non-flammable, and most can be used in indoor or outdoor applications. Each product yields a different finish and effect. Patine Calce, shown here, gives an antique Italian patina finish. (954) 331-8020. www.stuccocreativa.com.
Courtesy Omega Products Sto Corp. Powerwall Stucco is a factory-blended cement, lime, fiber, and additives mix that yields a Portland cement stucco base coat that is breathable and resists wind-driven rain and ultra-violet light, says the maker. It can be used to create a smooth or textured exterior. (800) 221-2397. www.stocorp.com. Omega Products. Akrotique acrylic sealer gives a mottled, uneven finish to stucco that mimics the look of Old World stucco. The sealer is available in a range of standard semi-transparent colors and can be applied in few coats for a light shade or many coats for a deeper shade. The sealer may be applied to the company’s other products, such as ColorTek exterior stucco, Exterior E-Z Wall, and Interior E-Z Wall. (800) 600-6634. www.omega-products.com.
