Residential
Treating Bolt Holes in Wood
When treating cut ends with preservative, don’t forget to treat the bolt holes too. An easy way to do this is to dunk your bolts in the preservative first, and then put them in. It seems to help if you spin the bolts around as you insert them into the hole.
Todd Oskin
From online comments
