Glossy vs. Flat
Which type should you choose in an exterior paint?
Exterior Finishes
High-gloss paints typically contain more paint resin and less pigment, and perform better and last longer than the low-gloss or flat paints.
Flat paints tend to pick up dirt and absorb water more readily than the high-gloss paints. Because of this, mildew growth is often greater on the flat paints.
To learn more about exterior finishes, visit the JLC Field Guide
