Innovative Products 2002
This year’s roundup of problem-solving tools and materials will help you build better and work smarter
Like Water off a Duck’s Back Furring out exterior siding helps paints and materials achieve their maximum life span and allows infiltrated water a way to get back outside the building before it can do any damage. Traditionally, the problem with including a drainage plane has been the tedious and time-consuming process of furring out windows, doors, and trim and the associated headaches of dealing with oddsized extension jambs. Benjamin Obdyke’s Home Slicker provides a fast and easy way to integrate a drainage plane into modern home building methods. It’s a nylon matrix with vertical channels that promote rapid drying of siding and allow infiltrated water to run out the bottom. The best part is that Home Slicker is only
