Foundation Footing Fundamentals
If you know your soil bearing capacity, following these practical guidelines will ensure strong footings
14 MIN READ
Spanning Over a Soft Spot
Some sites have occasional soft spots in otherwise good soil. You usually discover such spots when you’re driving stakes for the footing forms — you hit a stake and it just about disappears with one blow. Maybe there’s a layer of soft clay that rises from an old lake bottom at an angle and just intersects your trench in one or two places. If a stake sinks in easily under hand pressure, there’s cause for concern.
You may have to excavate down past the soft spot and place a deeper footing, then pour a taller wall. Or you may have to pier down through the soft material to get a bearing on good material. Another option is to excavate out the soft soil and replace it with compacted gravel or low-strength concrete, also called “lean fill” (see “A Quick Cure for Problem Soils,” 1/00).
But in many cases, widening the footing is the simplest solution. If you’ve got a 16-inch footing, increasing that to 32 inches doubles your bearing area, making the footing suitable for soil with half the capacity.
If you increase the footing width, the code requires an increased thickness as well. That’s because a footing that’s too wide and not thick enough will experience a bending force that could crack the concrete. The projection of the footing on either side of the wall is supposed to be no greater than the depth of the footing.
So, for example, a 32-inch-wide footing under an 8-inch wall would need to be at least 12 inches thick. Instead, however, you could reinforce the footing with transverse steel (running in the crosswise direction, not along the footing). In most residential situations, #4 rod at 12 inches o.c. will be plenty for 8-inch-thick footings up to 4 feet wide. The steel should be placed about 3 inches up from the bottom of the footing.
Even though a lot of contractors do it, one thing that will not help you span a soft spot in the soil is to add more steel along the long dimension of the footing. Throwing more longitudinal steel into a footing in this situation is just a waste of time and money. If you’re going to add lengthwise steel, put it where it will do some good: in the wall, not the footing. Just as a 2×12 on edge is way stronger than a 2×4 on the flat, steel at the top and bottom of an 8-foot or 9-foot wall does much more work than steel placed into a skinny little footing. A wall with two #4 bars at the top and two at the bottom can span over a small soft area with no problem.
