Framing Rake Walls Redux
In the upcoming September issue of JLC, Tim Uhler will explain the way he frames and sheathes rake walls, and even sides gable ends, before standing them. For a preview, watch this time-lapse video:
This is a topic he tackled for JLC back in 2006 (see “Framing Rake Walls,” 9/06). But ever learning, he and his crew have improved their methods. The differences he listed:
  • We stopped using rafters to do the layout on the wall, instead we use the math [to be explained in detail in September] and layout along double top plates. This keeps the wall much stiffer when we lift it.
  • We don’t snap the studs, we find one stud and layout along the rake, calculating the spacing.
  • We measure in each stud and cut at a cut station so the cut man can keep better track of scrap.
  • We frame the overhangs on the wall before lifting and install our soffit, which keeps the wall very straight. We also put a flat piece of metal on the overhang before installing the barge to keep the plumb cuts on the barge from opening.
  • We now do much more than just simple gables: We’ll frame a double gable, gable with an opening in it, gables with two different slopes, etc.
You can see more of what he means in his Google+ album documenting a recent project, which has about a dozen different gables. The entire album of photos and videos is a wonderful case study in the foundation and framing techniques that Tim has shared with JLC readers over the years.
