Practical Engineering: Wood I-Joist Fundamentals
Most contractors that frame residential and light-commercial buildings are now (or soon will be) using wood I-joists. For builders accustomed to the shape and heft of conventional sawn lumber joists, the weight and appearance of a typical wooden I-joist often raises an immediate concern about its ability to handle the load. How could such a thin, lightweight material carry as much as a sawn 2×10 or 2×12? Situations like the one in the photo above seem to defy common sense. How can you possibly remove so much of the I-joist web in the middle of a span? Yet the hole chart for that particular I-joist allows you to. Can you imagine doing that with a sawn joist? However,
John Siegenthaler, P.E.
John Siegenthaler, P.E., operates Appropriate Designs, a building systems engineering firm in Holland Patent, N.Y. He is the author of the course materials for the ASSE 19210, Hydronics Heating and Cooling Installer Professional Qualification Standard, as well as the author of "Modern Hydronic Heating for Residential and Light Commercial Buildings," and “Heating With Renewable Energy” (both published by Cengage).
