Bathroom Venting that Works
Keep the ductwork warm and pitched toward the exterior.
Bathroom ventilation in one form or another is not only desirable, it is also required by building codes. Although its main purposes are to provide a healthful exchange of air and remove odors, ventilation also helps in controlling excessive humidity. Thus, in a residential bathroom with no window that opens to the outside, you need a ducted electric fan to meet code requirements. The problem here is that a fan will only remove stale air and moisture when it is turned on, and a window will only do the job when it is opened. Both are at the mercy of the occupants. Of course, moisture removal from a bathroom can be accomplished simply by leaving the bathroom door
