Installing an Over-the-Post Handrail – Part II
Loose-fitting dowels and five-minute epoxy allow fine adjustments in the assembly
8 MIN READ
Installing an Over-the-Post Handrail – Part II – Continued
I fill the internal void in the bullnose end with solid blocking, using screws and lots of construction adhesive. I’m mindful to place the screws where I won’t drill into them later when setting balusters. The bullnose riser must be securely fastened to the floor, and the tread well-fastened to the riser, using lots of adhesive. Since the height of the volute varies with different fittings and rail heights and with stair rise and run, always use an adjustable volute newel. (In my work, I typically use a custom newel.) Most adjustable newels have a long, 1 1/2-inch-diameter removable dowel inserted into a deep hole centered in the base.
The dowel is removed to cut the newel to length, then glued back into the bottom of the newel with wood glue or epoxy.
Adjustability. It’s almost impossible to bore a perfectly plumb mounting hole into the bullnose tread without a drill press, so I prefer to drill an oversize, 1 5/8-inch hole, to allow some adjustability. I drill the hole as deep as my spade-bit allows, then saw the dowel off about 1/8 inch shorter than hole depth. I drill a 1/4-inch-diameter hole in the bottom center of the hole, and another in the center of the dowel. I drive a 3/8-inch-by-3-inch dowel screw halfway into the dowel. (The easiest way to do this is to chuck the screw in your drill using a driver kit, an accessory typically offered by stair-parts manufacturers.)
Then, with a generous application of five-minute epoxy, I screw the newel down onto the tread. The dowel screw pulls the shoulder of the newel down square onto the tread, and the epoxy fills the gap between the dowel and the oversize hole. When the epoxy sets, the structure is monolithic and very strong.
Now I check the fit of the rail assembly — it should drop down onto the pin tops of both newels. After testing the fit, I loosen the rail bolts, apply wood glue to the joints with a Popsicle stick, and snug the bolts up tight again with the railing in place. When the glue has grabbed, I remove the rail stands and install the balusters.
Fitting Balusters
In most cases, to meet code spacing requirements you’ll need to install three balusters per tread. And because the height between railing and tread grows from front to back, you also need three different baluster lengths per tread, each typically about 2 1/2 inches longer than the last. This is a fairly standard differential that suits most code-compliant stair pitches.
Since we’ve already located the front baluster center, locating the other two centers is as simple as stepping off in thirds back to the riser. A quick way to do this is to use the 12ths scale on your framing square and a compass to divide and transfer the distance in equal fractional segments.
The balusters I’m using on this demo stair, provided by Coffman Stairs (276/783-7251, www.coffmanstairs.com), have adjustable blocks on top, designed to make it easier to match the angle of the rail. At the bottom, the balusters have standard 3/4-inch dowel pins. Dowel screws provide a much stronger connection than glued dowels for securing the balusters and I generally prefer to use them, but in this case I drill 3/4-inch cup holes in the treads at the marked centers.
With the railing clamped overhead, I use the laser plumb bob to accurately locate the top of each baluster against the railing. Holding the baluster in position, I scribe the angle against the railing, then cut it about 1/4 inch long so that it will fit up inside the plough. After adding a small amount of glue (to avoid drips), I fix its position with a pneumatic brad: first the pin, then the block.
Fillet — a thin strip of matching wood made to fill the plough between balusters — ensures that the baluster won’t move off the brad and gives the underside of the railing a nice, finished appearance. It’s a time-consuming task to cut fillets, but simply butting a square-top baluster against a flush-bottom railing practically guarantees that you’ll have visible gaps at the top, and a much weaker assembly that relies only on the brads for holding power.
The last baluster before the landing newel happens to coincide with the curving up-sweep of the gooseneck. Therefore, I have to scribe and cut the baluster top using a saber saw. A curved fillet piece is typically sold with the gooseneck fitting to finish the underside.
Baluster spacing under the volute’s spiral is no different than the standard tread spacing. I use my compass and laser plumb bob to set the centers one at a time, at the same intervals as the common baluster spacing. Baluster layout starts against the second riser up and works out from there around the spiral. I eyeball the volute’s radius, swing an arc with the compass, and find the rail’s precise centerline by placing the plumb bob over the arc.
I install the level landing balusters and those wrapping the volute newel first because these are all square-cut to common lengths. After screwing them down on their dowel bolts, I set the assembled railing over them.
At this point I can cut and fit the rake rail balusters. If I’m using balusters with wood tenons, I’ll go ahead and glue the railing to the newel pins. Then I can rock the rake balusters into place, dropping them into the cup holes in the treads and lining them up with layout marks on the underside of the railing, which I make using the laser. I work from the bottom of the stair up; this makes it easier to brad-nail the balusters to the railing. I’m careful not to overdrive the brads and jack the railing up.
If I’m using dowel screws, which I prefer, I’ll wait to glue down the handrail until I’ve marked and cut the balusters, and threaded them into place.
Fitting the fillet pieces completes the baluster installation. I clean up the railing assembly, beginning with a small plane, a spokeshave, and 36-grit paper to fair the joints, then step down through 80-, 120-, and finally 180-grit papers to finish.
Jed Dixon is a master stair carpenter in Foster, R.I., and a regular presenter at JLC Live. Thanks to Crown Heritage for providing all the railing parts for this demonstration staircase.
Jed Dixon
Jed Dixon is a stairbuilder in Foster, R.I., and a founding presenter at JLC Live.
