Residential
Dual-Layered Insulated Sheathing
LP Building Solutions
LP NovaCore Thermal Insulated Sheathing combines sheathing and insulation, allowing for one-step installation. One-inch XPS foam and 7/16-inch OSB are bonded together to create an R-5 insulated wall panel that can be handled, cut, and drilled like OSB. Panels may be installed vertically and horizontally, provided that all edges are blocked or otherwise supported. NovaCore is available in nominal lengths of 8, 9, and 10 feet, and panels are reportedly backed by a 20-year warranty. lpcorp.com
