Products
Products JLC’s Products by Leland Stone Fast Footer The hardest part of pouring a concrete pier is attaching the tube form to a cobbled-together lumber footing form. One solution is Bigfoot, a recycled plastic footing form that adjusts to fit 8-, 10-, or 12-inch tubes, and that easily connects to the tube with a few screws. The assembly works like a single piece, so it’s easy to set and level, and the form can be left in place after the pour. The flared design shapes a smooth, coneshaped footer on the pier, and you can even turn a spare form upside down and use it as a funnel while pouring mud into the other forms. Bigfoot has been
