Products
Products JLC’ s Products by David Frane Prefab Vinyl Railing Need a porch railing that lasts? The Finyl Rail structural vinyl railing is extruded from rigid PVC and has a hefty wall thickness of 5/16 inch. The railing system comes in a variety of round and rectangular profiles, and can be custom fabricated to match requirements for rise/run, stair radius, inside and outside corners, and other design considerations. All components are prefabricated and shipped preassembled; oversize systems are provided in smaller sections that are then fit together on site. The seamless railings are coated with a durable high-gloss finish to resist corrosion, even when exposed to salt air, and are mounted over steel brackets. All fasteners are concealed. Available in white (round
David Frane
