Focus on Energy: Adding a Floor Heating Loop
One major consideration when installing a floor heating circuit in an existing hydronic system is the need to control water temperature. Most hydronic systems in the U.S. operate at water temperatures necessary for common fin-tube baseboard convectors — usually in the range of 160° to 200°F. In a radiant floor, however, temperatures this high will overheat the slab and possibly cause cracking. Providing lower-temperature water to the floor heating zone, however, may cause flue-gas condensation at the existing boiler. Large-scale floor-heating projects use motor-operated four-way mixing valves and electronic controls costing as much as $1,000. But small projects, such as one-room additions or bathroom remodels, don’t have room in the budget for this kind of equipment. Here are two piping strategies for adding
John Siegenthaler, P.E.
John Siegenthaler, P.E., operates Appropriate Designs, a building systems engineering firm in Holland Patent, N.Y. He is the author of the course materials for the ASSE 19210, Hydronics Heating and Cooling Installer Professional Qualification Standard, as well as the author of "Modern Hydronic Heating for Residential and Light Commercial Buildings," and “Heating With Renewable Energy” (both published by Cengage).
