Restoration Primer: Wet Sills and Rotten Posts Radiate Damage
The following two case studies show that it’s best to do repair work right the first time. Otherwise larger problems are likely to crop up down the road. Case One: Bulging Plaster The owner of an 1830s timberframed cape-style house was concerned about an unusual bulge in the plaster near the corner of an exterior wall. The plaster bowed out from the surface of the wall in a horizontal area 6 inches high and 5 feet long. It bowed out from the flat surface of the wall about 1 1/2 inches. The plaster had been in good condition less than two years earlier, but when I checked it out it was completely separated from the wood lath beneath. The
