Solar Innovations. As more homeowners opt for conservatory styling for room enclosures, Solar Innovations conservatories offer numerous options. Choose from standard, semi-standard, and fully customized designs ranging from traditional to modern. All-aluminum construction is available in nine standard colors, or choose aluminum exterior/wood interior options featuring solid mahogany and southern yellow pine laminate, or other species upon request. 800.618.0669. www.solarinnovations.com.
Gorell. Topping off the Presidential and U.S. sunroom series is a new Kote Gold foam roof system that provides improved thermal performance and a more attractive appearance. The insulating foam panels are available in 3- or 4-inch-thick versions with R-values of 12.75 or 17, respectively. The panels' snap-lock installation means no screws or I-beams are visible inside the room. 724.465.1800. www.gorell.com.
Leisure Woods. Lake Wood Series gazebos are all constructed from clear D-select-grade Western red cedar in a variety of traditional and contemporary designs reflected in the styles of roof, valances, and balusters. Sizes range from 10 feet to 28 feet. An array of finishing and detail options let clients create screen- or window-enclosed gazebos or pavilions, in addition to open styles. New steel roofing options impart additional color to the structure. 888.442.9326. www.leisure-woods.com.
Four Seasons Sunrooms. ConservaGlass Plus with self-cleaning technology makes keeping sunroom windows clean easier than with traditional glass, the maker says. Eight microscopic protective layers give the glass EnergyStar qualification and a center-of-glass R-value of 4. Additionally, a titanium dioxide coating reacts with UV rays to decompose organic material, while a highly smooth silicon dioxide coating helps dirt rinse away easily. 800.368.7732. www.fourseasonssunrooms.com.
For more product information, visit ebuild.com, Hanley Wood's interactive product catalog.
