PAM Fastening E-Z Driver
StoryID
1497320
ToolNumber
1
ComponentId
tcm:78-1257433
Get a Grip. The E-Z Driver is a simple but useful drill accessory for fastening deck boards or squeezing screws into awkward spots where you can use only one hand. It consists of a chuck that houses a replaceable Phillips or square drive bit, plus four spring-loaded ball bearings that hold the screw in place. A ring at the base lets you set screw depth; once that depth is reached, an internal clutch releases the screw. The device costs about $17. PAM Fastening, 704/394-3141. www.pamfast.com
Go to JLC
