Prazi Beam Cutter
StoryID
1487374
ToolNumber
1
ComponentId
tcm:78-1256853
Go Deep. Getting through a 6×6 or a 4×4 with a 7 1/4-inch circ saw typically requires multiple passes, but with a Prazi Beam Cutter attached you can cut up to 12 inches in a single pass. Also available for wormdrives and hypoids, the tool is perfect for getting through heavy timbers and SIPs panels, and for gang-cutting rafters and stair stringers. It sells for $160. Prazi, 800/262-0211. www.praziusa.com
Go to JLC
