Rockwell Introduces New Oscillating Tools
Rockwell unveiled four new Sonicrafter oscillating multi-tools. The new models feature an increased oscillating angle and more power. They also incorporate a more tapered and compact design and an increased accessory count for each tool.
According to the manufacturer, increased power and a greater oscillating angle mean the tool works faster, creates more aggressive cuts, and generates quicker results. The top of the line F50 (RK5141K) features a cutting angle of 5.0° and the F30 (RK5131K) a cutting angle of 4.0°.
The F50 is said to cut five times faster than the line’s namesake, the Sonicrafter (RK5121K) and, according to Rockwell, features an industry-best maximum cutting load of 35 pounds. Meanwhile, the F30 features a cutting load of 30 pounds and the RK5121K features a 21 pound cutting load. The tools also offer electronic constant speed control which maintains the tool’s cut rate under load. Rockwell’s designers cut down on vibration created by an increase in oscillation angle by building in a counterweight to offset it.
The tools are compatible with Rockwell’s Universal Fit accessory system, which enables all the tools under the Sonicrafter line to accept accessories from other brands without using adapters. The tools are fitted with the Hyperlock tool-less blade change system, which prevents accessory slippage by providing one ton of clamping force.
The country of origin for all the tools is China and the 20-volt max cordless version of the tool (RK2863K) will not be available until the fall.
Sonicrafter F50 (RK5141K) – $139
Oscillating angle: 5.0°
Motor: 4.0 amp
Speed: Variable
Max. cutting load: 35 pounds
weight: 3.3 pounds
Oscillations per minute: 11,000-20,000
Cord length: 10 feet
Interface: Universal accessory
LED Light
Universal Fit accessories: 34 ((4) 1 3/8-inch end-cut blades ((1) metal, (2) precision, (1) standard), (1) 3 1/8-inch HSS semicircle saw blade, (1) rigid scraper blade, (1) sanding pad, (26) sanding sheets, hard case)
Warranty: 3 years
Sonicrafter F30 (RK5131K) – $119
Oscillating angle: 4.0°
Motor: 3.5 amp
Speed: Variable
Max. cutting load: 30 pounds
weight: 2.9 pounds
Universal Fit accessories: 32 ((3) 1 3/8-inch end-cut blades ((1) metal, (1) precision, (1) standard), (1) rigid scraper blade, (1) sanding pad, (26) sanding sheets, hard case)
Warranty: 3 years
Sonicrafter (RK5121K) – $79
Oscillating angle: 3.2°
Motor: 3.0 amp
Speed: Variable
Max. cutting load: 21 pounds
weight: 2.9 pounds
Oscillations per minute: 11,000-21,000
Universal Fit accessories: 31 ((2) 1 3/8-inch end-cut blades, (1) rigid scraper blade, (1) sanding pad, (26) sanding sheets, hard case)
Warranty: 3 years
20V Sonicrafter (RK2863K) – $159
18-volt Lithium-ion battery
Motor: 3.0 amp
Speed: Variable
weight: 2.9 pounds
Universal Fit accessories: 27 ((1) 1 1/8-inch standard wood end cut blade, (1) 3/8-inch Bi-metal end cut blade, (1) 3 1/8-inch HSS semi-circle blade, (1) rigid scraper blade, (1) sanding pad, (20) sanding sheets, (1) carbide semicircle (grout) blade, (1) 20 volt Lithium-ion battery, (1) 30-minute charger, carrying bag)
Warranty: 3 years
