Product Watch: Veritas Small Router Plane
StoryID
1507166
ToolNumber
1
ComponentId
tcm:78-1629602
Small Router Plane
If you need to cut small recesses, grooves, or dadoes, Veritas offers this small router plane for fine woodworking. At 7 ounces, the plane is 3-1/4-inches wide and 2-1/4-inches deep with a 1/4-inch wide high-carbon steel blade and a cast-iron body. Position the blade inboard for closed-throat use, or outboard for bullnose work. Behind the blade is a clamping knob that allows for visibility and chip clearance. Price: $49, replacement blade $9. 800-267-8735.
