Warner Tools Utility Knife
Warner Tools' new utility knife, called Rasp 'N' Knife, comes with a built-in smoothing rasp.
StoryID
500992
ToolNumber
1
ComponentId
tcm:78-1626570
Looking for a utility knife that smooths rough edges of drywall? Then here’s one for you. Warner Tools’ new utility knife, called Rasp ‘N’ Knife, comes with a built-in smoothing rasp. An ideal tool for drywall hangers, the knife has a rigid, fixed blade for heavy-duty cutting. Its handle easily disassembles so users can change blades or adjust the cutting depth. The blade adjusts from 11/16-inch to a 13/8-inch edge.
The knife comes with three standard utility blades and sells for under $5. For more information, contact Warner Tools, 877-WARNER-1; www.warnertool.com.
