In Focus: Reciprocating Saw; Miter Saw, and other Power Tools
Ridgid. The compact head of the R82233 12-volt Right-Angled Impact Driver makes it easy to reach awkward spaces. The driver boasts a variable-speed reversing switch and a 1/4-inch quick coupler, as well as an ergonomic handle covered in a rubberized overmold. A compact, high-capacity battery pack and a Rapid Max charger are included. 866.539.1710. www.ridgid.com.
DeWalt. With a 10-amp motor that delivers up to 2,800 strokes per minute, the DW304PK reciprocating saw is designed for heavy-duty work. The four-position blade clamp allows for flush cutting, while the keyless lever-action blade change allows the user to switch blades quickly. 800.433.9258. www.dewalt.com.
Makita. The LS1214F 12-inch miter saw is equipped with a fluorescent light to illuminate the cutting surface. The portable saw boasts precision bevel cutting up to 45 degrees left and right with a new positive stop at 33.9 degrees left. A pivoting fence supports materials for miter cuts. 800.462.5482. www.makitatools.com.
Senco. The cordless DuraSpin DS275-18V screwdriver enjoys a 3,000 rpm motor and drives 50 1- to 3-inch screws between reloads, using DuraSpin collated fastening strips. A reverse switch backs out driven screws. It comes with two 18-volt batteries, charger, drywall and wood nose pieces, two square drive bits, and a Phillips drive bit. 800.543.4596. www.senco.com.
Ryobi. With a thin barrel designed to be easy for one-handed trimming, the TR45 Laminate Trimmer weighs in at only 3 pounds with an upgraded 4.5-amp motor. Complete with separate bases for laminate trimming and woodworking, the trimmer runs at 25,000 rpm and has a 10-foot cord. 800.525.2579. www.ryobitools.com.
