Bosch. The 12524-03 24-volt Cordless In-Line Hammer Drill is designed for use in light concrete, wood, and masonry applications and features a dual-mode selector with drill-only and hammer drill operations. The selector switches between high torque from 0 to 750 rpm and high speed from 0 to 2,000 rpm. The in-line design eases vertical or horizontal drilling, the maker says, and the soft grip handle increases comfort. One 24-volt battery and a one-hour charger are included. (877) 267-2499. www.boschtools.com.
Ridgid. The 10-inch Cast Iron Table Saw, Model TS3650, features a 120/240-volt, 13/6.5-amp enclosed fan-cooled induction motor designed to run cooler. Its 360-degree-rotating casters are engaged using a foot pedal; when disengaged, the table saw rests on adjustable leveling feet. The saw also features 36-inch right and 12-inch left rip capacity, a T-slot miter gauge, and a locking and self-aligning rip fence. (800) 474-3443. www.ridgid.com.
Makita. The 6917DWDE 12V 3/8-inch Drive Cordless Impact Wrench features a compact design -- measuring 65/8 inches long -- and a light weight of 31/2 pounds. The impact wrench has a rubberized grip and a two-piece motor with a replaceable armature, field, and externally accessible brushes for greater serviceability, says the maker. An impact resistant magnesium alloy hammer case is included. (800) 462-5482. www.makitatools.com.
DeWalt. A line of 9.6-, 12-, and 14.4-volt cordless impact wrenches and impact drivers (DW054K-2 impact driver shown) are designed to drive large fasteners without the typical kickback, says the maker. The wrenches feature a 3/8-inch square drive anvil with hog ring retention for easy socket changes or a 1/2-inch square drive anvil with detent pin retention for solid socket retention. The drivers feature 1/4-inch hex quick release chucks and anti-slip grips. (800) 433-9258. www.dewalt.com.
Porter-Cable. The 175 PSI High Pressure Framing Nailer Combo Kit weighs 25% less than other pneumatic framing nailers, the maker says, and has a rubber grip, a tool-free adjustable depth control and magazine release, and a trigger to switch between restrictive or contact. The kit comes with a 175 psi high pressure oil lube side stack compressor with console, a 50-foot air hose, 3/8-inch fittings, the High Pressure Framing Nailer, and pipe joint tape. (888) 848-5175. www.porter-cable.com.
For more product information, visit ebuild, Hanley Wood's interactive product catalog.
More about Porter-Cable
Find products, contact information and articles about Porter-Cable
