Not All Windows Leak
To the Editor:
In the article
"Water-Managed Wall
Systems" (3/03), Joseph Lstiburek states, "In America, we
build as if windows don't leak" and "All windows leak at the
joints." He cites "a survey of over 3,500 vinyl windows that
were less than two years old" in which "20% had already begun
to leak." My concern is that the general public reading this
article might conclude that all windows and doors leak, when in
fact this is not necessarily the case. This leakage problem
might be true with vinyl windows and doors. However, at Pella
Corporation, every window and door gets tested for air and
water infiltration before it leaves the factory.
As the director of product support for the New Hampshire and
Maine branch of Pella Windows & Doors, I teach
contractors how to properly install windows and doors,
stressing the water-management system, specifically the
"rainscreen" principle and how it relates to a
window-wall.
Chuck Kaskiewicz
Brick Veneer No-No
To the Editor:
In the article
"Water-Managed Wall
Systems," the brick veneer drawing on page 57 shows
galvanized or stainless-steel nails or screws as brick ties.
This is a real no-no!
All building codes that I am aware of require corrugated metal
ties for veneer over wood studs. The attachment of these ties
must be into the studs.
A nail or screw would not provide the proper amount of bond
area. Also, to install a nail over a freshly laid course of
brick would be very hard. Plus, a nail or screw would not have
a drip bend, which would lead to water being drawn into the
interior.
We recommend a minimum 2-inch air space and use
stainless-steel wall ties with stainless-steel screws. On any
veneer over 10 feet high, we use adjustable wire ties.
At the base of the cavity, we install Mortar Net. On stone
veneer, we use Inka or Hydroduct drainage mat in the cavity for
the entire height.
Michael DeBlasio
Masonry contractor for 31 years
Littleton, Mass.
Fast and Loose
To the Editor:
The article
"Water-Managed Wall
Systems" by Joe Lstiburek addresses an area of intense
interest in the construction industry and has a lot of useful
information. However, there are parts of it that play a little
fast and loose with technical details.
For example, the author uses, seemingly interchangeably, the
terms "tarpaper," "cheap felt paper," "paper," and "felt paper"
several times. I assume he is referring to asphalt-saturated
organic felt. In other places he refers to "Type D coated
paper," which I assume to mean asphalt-treated kraft paper.
Asphalt-saturated organic felt is the only material
specifically described to be used as a "water resistive
barrier" in the International Building Code, and it is
one of two materials specifically described in the Uniform
Building Code and the California Building Code,
kraft waterproof building paper being the other.
Drainage of a wall is an important water management technique,
but drying by evaporation can be equally effective. Creating
air spaces by furring out wood clapboards may result in better
drainage, but it also creates a fire hazard by introducing an
unblocked chimney into the exterior wall system. It may
actually violate Section 708.3 of the Uniform Building
Code. Finally, it is largely unproven whether this is
really necessary to create a wall system that can adequately
manage water.
In the section on window leakage, vinyl windows may have been
an unrepresentative choice because they have unique problems,
particularly when used with stucco. The coefficient of thermal
expansion of vinyl (PVC) is nearly 4 times that of aluminum and
nearly 14 times that of wood. When used with stucco, which
tends to shrink slightly as it cures, vinyl frames appear to
contract sufficiently to provide a small but significant gap
around window perimeters. Water intrusion into the gap may be
sufficient to cause fairly quick degradation of paper-based
weather-resistant barriers, resulting in wetting of framing and
sheathing. Even when plastic or all-bituminous flashings are
used, it appears that water intrusion can reach and deteriorate
the surrounding paper-based weather-resistant barriers. A
similar gap occurs around aluminum and even wood windows, but
it is so comparatively small that water intrusion is not
typically a problem unless other flaws exist. It appears that
the difference between aluminum and vinyl is enough to enable
aluminum windows to function successfully while vinyl may not,
even though the detailing and installation are the same.
I want to emphasize that Dr. Lstiburek is doing a great
service by providing this type of information. I just want to
see a little more rigor in the terminology and
technology.
Thomas K. Butt, FAIA
Interactive Resources
Point Richmond, Calif.
Housewrap Maker Counters
To the Editor:
Dr. Lstiburek
("Water-Managed Wall
Systems") offers an excellent discussion about proper
installation of materials to shed water and concludes that
design alone will not keep all moisture out of a wall system.
It follows that successful water management must depend upon
durability and performance of the building materials, including
weather resistive barriers. This is contrary to his point that
"the difference between one building paper and another is
really a minor issue."
Tyvek is made from spunbonded polyethylene fibers, a unique
structure offering an effective combination of durability,
water and air holdout, and breathability. In addition, Tyvek
does not absorb water, is not a food source for mold, and will
not degrade in the presence of water, in contrast to building
paper.
In a field study of stucco walls, weather membranes were
removed and tested to measure loss in water resistance. Not
only was the initial water resistance of Tyvek significantly
higher than that of building paper, there was no deterioration
in the water resistance of Tyvek compared to building paper,
which lost repellency. Also implied is that the transfer of the
print from the Tyvek to the stucco is an indication of bonding,
destroying water repellency. Concluding that stucco should
never be used with a housewrap is inaccurate. As applied,
stucco contains significant amounts of water; the ink is water
soluble, so transfer may occur but does not indicate physical
adhesion.
DuPont will continue to support product performance. As a
science-based company, we believe in rigorous testing, and we
appreciate the opportunity to share our data.
Catherine M. Wilson
Stucco Market Manager
DuPont Tyvek Weatherization Systems
Home Shows Rule
To the Editor:
I thoroughly enjoyed Tom Peterson's article
"Marketing by Home
Show" (Business, 4/03). I am the organizer of a
small local co-op home show, and many of our exhibitors are
looking for information like this.
Having organized six shows, I can say that this article was
right on target. Many others involved in the home industry
could benefit from exhibiting in a home show. Half of my new
business comes from our show. The other half comes from our
show's website. I am busier than I have ever been. Our
builders' association receives a substantial part of its
funding from the admissions charged. They also supply the staff
to operate the show, which is a great way for the association
to connect with the community. Many of the exhibitors network
with each other, while seminars provide consumers with valuable
knowledge. Home shows are a lot of work, but they are by far
the best marketing tool I have seen for the construction
industry.
Richard C. MacCrea
Mountain House Plans
via e-mail
Coffered Ceiling Details
To the Editor:
Regarding the article
"Building a Coffered
Ceiling" (4/03): Note the outside corner molding used by
early craftsmen. This molding installs quickly, provides a
shadow line, and conceals gaps while allowing for expansion and
contraction in the adjoining boards -- resulting in fewer
callbacks.
Richard Alexander
New Market, Md.
