Three-Coat Stucco, continued
Note that lath must be installed with the long dimension
perpendicular to the supports. Also, metal mesh must be
installed with the right side up, or the stucco will slide off
the building. At corners, make sure that the lath is not
installed too tightly or else it will not be embedded
sufficiently in the scratch coat and the normal expansion and
contraction of the building due to temperature changes will pop
the stucco off. To prevent this, we "pooch out" the lath at
corners, pulling it away from the building so there will be
room for the stucco behind it. Alternately, you can apply
cornerite, an expanded metal lath designed for this purpose
(Figure 3).
| Figure
3. This house is ready for stucco. Special care
is taken to ensure the lath is not pulled too tightly
at corners. If it is, the stucco will pop off over
time. A lath accessory called cornerite (left) can also
be used at corners to ensure proper
embedment. |
The Mix
Although it comprises only about 20% of the finished product,
Portland cement is what makes stucco stucco. Most cements are
of good quality these days, so it really doesn't matter which
brand you use. Watch out for older bags of cement, because
humidity can partially react with the cement over time even if
the bags have never been opened.
Some cement will have plasticizers added. If you use a
plastic cement (as I do), do not add lime or other additives.
Cement is typically packaged in 94-pound sacks, which equals
one cubic foot. This is helpful when you are trying to figure
out proportions.
Figure
4. Clean sand, dry cement, and the correct
amount of water are key to a good stucco
mix. |
Sand. Stucco is
mostly sand, so you should use clean, sharp, good-quality sand
(Figure 4). Good sand is the key to dense base coats, with
either traditional three-coat or the one-coat method. Ask for
and get verification that your subcontractor is using sand that
conforms to ASTM 897 for gradation and has a minimum SE (sand
equivalent) rating of 70. (SE is a designation for the amount
of fines in the sand.)
If you want to check the sand yourself, take a random
sampling from various areas of the sand pile. A glass jar test
will quickly tell you if the sand is clean. If it's dirty,
you'll see silt or other contaminants; more than a very slight
amount of contaminants is cause for concern.
Soluble salts or excessive fines are also harmful to the
stucco. Salts can result in efflorescence, while clay fines may
expand when wet, absorbing extra water, and causing the stucco
to be weaker when it dries.
If you have any doubts about the quality of the sand the
stucco contractor is using, I suggest setting aside a bag for
future evidence, just in case there are problems.
Water. Clean,
potable water is the rule. It takes only 2.8 gallons of water
to fully hydrate a sack of cement, but it takes about 6 gallons
per sack to make a workable mix when using good-quality sand.
Poor-quality sand may require more water, and you might use up
to 10.5 gallons of water per sack if you have added lime to the
mix.
Application
With proper substrate, preparation, and materials, you are
more than halfway to a good stucco job. Now it's up to the
applicators to mix the stucco and apply it correctly.
Figure
5. The author's crews pump brown and scratch
coats (left). Finish coats (right) are
hand-troweled. |
Almost all of our base coat stucco is applied with a plaster
pump (Figure 5). The plastering pump is temperamental: The mix
has to be blended properly -- otherwise it will not slide well
through the hose -- and the equipment must be in good working
order. Although pumped plaster is generally a slightly wetter
mix, it still results in a perfectly acceptable job. Hand
application with a trowel is simpler, but it actually requires
more skill. Given the proper mix, an experienced plasterer with
a trowel can provide a stronger, denser, more carefully applied
job, but this is not always the case.
