Download PDF version (1070.6k) Log In or Register to view the full article as a PDF document.
Launch Slideshow
Installing French Doors, Images 1-8
  • http://www.jlconline.com/Images/1385810315_1002_JLC_installFrenDoor_00a_tcm96-1170788.jpg
    true
    600
    Fix the leaks before they start with careful framing and the proper sill pan, flashing, and sealant.
  • http://www.jlconline.com/Images/1634111508_1002_JLC_installFrenDoor_01a_tcm96-1170790.jpg
    true
    600
    French doors have a reputation as being leak-prone, but most problems stem from improper installation. Here, a spray-rack test shows water leaking between the sill and the subfloor.
  • http://www.jlconline.com/Images/161176024_1002_JLC_installFrenDoor_02a_tcm96-1170794.jpg
    true
    600
    Both one-piece metal door pans and multipiece plastic door pans should be fully bedded in a high-quality polyurethane sealant, not silicone caulk.
  • http://www.jlconline.com/Images/716236579_1002_JLC_installFrenDoor_02b_tcm96-1170798.jpg
    true
    600
    A multipiece plastic door pan
  • http://www.jlconline.com/Images/1503181417_1002_JLC_installFrenDoor_02c_tcm96-1170801.jpg
    true
    600
    Membrane pans should always be used with compatible flexible corners and sealants from the same manufacturer; many plasticized sealants are incompatible with peel-and-stick flashings.
  • http://www.jlconline.com/Images/74690349_1002_JLC_installFrenDoor_03a_tcm96-1170802.jpg
    true
    600
    A pair of compatible flexible corner flashings set in beads of sealant are used in conjunction with 12-inch-wide peel-and-stick flashing.
  • http://www.jlconline.com/Images/2102854501_1002_JLC_installFrenDoor_03b_tcm96-1170803.jpg
    true
    600
    Together the two to form a membrane pan.
  • http://www.jlconline.com/Images/2051319152_1002_JLC_installFrenDoor_03c_tcm96-1170804.jpg
    true
    600
    Strips of 9-inch-wide side flashing complete the assembly.
In California, contractors have been heard to grumble that there are only two types of French doors: the kind that leak and the kind that are going to leak. When they have the first kind, they call my company, TLS Laboratories in Laguna Niguel. We’ve investigated plenty of leaking French doors over the years, and in our experience it’s usually the installation that’s faulty, rather than the door itself.
A hinged exterior French door is something like a very large jigsaw puzzle with a small number of pieces. If the pieces are assembled correctly, the pair of sash should fully compress the weatherstripping against the jambs and one another. If the fit isn’t quite right, the weatherstripping won’t compress and water will seep in around the sash. If a door is going to leak, it most often leaks here.
The next most common leakage area is the sill — not over it, but underneath it, usually as the result of insufficient sealant. Pans and proper flashings also help (I’ll talk about them later), but two fat beads of sealant running 6 inches down each trimmer and all the way across the pan — one toward the front edge of the door and another toward the rear edge — will stop a lot of water.
View Drawing, p. 7
Check the Opening
We’ve developed some effective strategies for installing leak-free French doors based on what we’ve learned. The first step is the most important: Start with a rough opening that is correctly sized and level, square, and plumb.
For shims and fasteners to function properly, rough openings should be 3/4 inch to 1 inch wider than the net frame size of the door, and 1/2 inch taller.
Level and square are easy enough to understand, but the concept of plumb requires a little explanation. It’s critical that both walls flanking the rough opening are equally plumb and in the same geometric plane. If they aren’t, the opening will be twisted — or cross-legged — and it will be impossible to install the door so that the sash sufficiently compress the weatherstripping.
For instance, a wall that is out of plumb by 1/8 inch on one side of the opening needs to be out of plumb by the same 1/8 inch on the other side to keep the opening in plane. If the opening is perfectly plumb on one side and slightly off on the other, then the installed door will be cross-legged. Doors that are cross-legged by more than 1/8 inch will have poor weatherstripping compression and will probably leak.
Some carpenters swear they can check for a cross-legged opening by closing one eye and trying to line up the trimmers. I don’t think this method is accurate enough to be reliable; it’s difficult enough to check with even the most accurate spirit level. I prefer to check rough openings and installed doors with a laser level or a pair of crisscrossed strings — or sometimes both.
Laser level. A three-beam laser level placed at floor level next to a trimmer or door jamb and aimed straight up can show exactly how far out of plumb that side of the opening is. If the difference between the left and right sides of the opening is 1/8 inch or less, the opening is close enough to being within plane. But if one side of the opening is 1/8 inch out from plumb and the other side is 1/16 inch in from plumb in the opposite direction, the combined 3/16-inch difference is too great and the framing must be corrected.
It’s always best if the measurements at both sides of the rough opening are the same, and the rough opening is exactly in plane. Houses can settle, so a door that starts out perfectly has a better chance of staying leak-free for a longer time.
String test. A pair of crisscrossed strings won’t tell you how far out of plumb the opening is, but they’re an extremely simple and cheap alternative to a laser level for checking cross-leggedness. I use staples or tape to fix the strings at the corners of the opening so they cross diagonally near the center. If the opening is in plane, the strings will gently touch each other at the crossing point. If the strings don’t touch, the opening is cross-legged by the dimension of the gap between them.
If there is no gap, I make sure to flip positions so that one string passes behind the other string instead of in front of it, and then I check again. If once again there is no gap, the opening is okay. But if there is a gap, I leave the strings in place and adjust the framing until the strings touch lightly in the center. It doesn’t take long to quickly double-check the door opening with the string test, even if you use a laser during framing.
Installing the Flashings and Sill Pan
In California it’s common practice to install flashings and millwork first and then the housewrap. If you install the wrap first, be sure to correctly cut out the opening: Instead of an X, make a level cut at the head and short diagonal cuts at the corners so that the top flap can be folded up and held in place with tape while the door is installed.
Pan systems. I would never install any door without a metal, plastic, or flexible-membrane door pan. As long as the pan is properly assembled and fits correctly, I don’t think it really matters much which kind is used.
Metal pans are sturdy and strong but can get damaged before the door is installed. We often see pans where the inside vertical lip has been flattened by the door installer or the flooring contractor. Plastic pans are a little more durable, but they have to be glued together to achieve a good fit, with the adhesive that comes with the pan system. Some installers lose track of the little glue tube supplied with the pan and either omit the glue altogether or try to replace it with silicone. Unfortunately, silicone won’t work, guaranteeing that the pan will leak.
I prefer membrane pans, which install quickly, always fit, and are cheaper than the other types of pans. I make membrane pans using a good self-adhering flashing and compatible premanufactured flashing corners, such as RainBuster 415 self-adhered flashing and RainBuster 425 inside and outside corners (800/473-1617, topindustrial.com). Fortifiber’s FortiFlash with GS100 corners also works well (800/ 773-4777, fortifiber.com). And I always use a compatible high-quality polyurethane sealant, such as RainBuster 900 or Fortifiber’s Moistop, when installing the pan.
I use polyurethane sealants — not silicone — with metal and plastic pans as well. The pans should fit snugly to each trimmer and be completely sealed to the subfloor with plenty of sealant. And if a deck is going to be installed on the exterior, the door pan will need to be counterflashed with the deck flashing before the door is set.
Vertical side flashings should be installed after the door pan is in place, even if the unit has nailing fins. Nail-on flashings are okay here, but peel-and-stick is even better. In either case, minimum flashing width should be 9 inches.
If the door has a nailing fin, I wait until after the door is installed to apply the top flashing. If it has a brick mold or flat casing, I go ahead and finish flashing the top of the opening, then add a metal drip cap after the door is installed.
