Contents:
Blowing Up the House
Shifting Sands
Eye on the Sky
Currents
Blowing Up the
House
When the big one blows through, it'll be the
windows and doors that keep the house
upright
Imagine a house on the beach facing sustained winds of more
than 75 mph and periodic gusts reaching above 120 mph. As long
as the house remains intact, these hurricane-strength winds
will blast the ocean side of the house with pressures measuring
over 40 psf. As the winds rise over the rooftop and rush around
corners, suction pressures in the wake of the blast will exert
even greater pressures on the sides and back of the house.
These pressures will reach their peak — as high as 75
psf of suction — at the building's corners, eaves, and
ridges, where the wind causes wild fluctuations in pressure
that push and tug erratically at cladding and roof
coverings.
That's if the house stays intact. Now imagine these winds
ripping out the neighbor's fence and hurling it through a
window or patio door. "Once you breach the envelope, the air
rushing in pressurizes the building just like blowing up a
balloon," explains Scott Schiff, a civil engineering professor
and director of Clemson University's Wind Load Test Facility.
Now you have positive pressure pushing from inside and negative
pressure pulling from outside. In the best case, these
pressures will blow out all the other windows in the house,
equalizing the pressure before severe structural damage can
occur. More disastrous (and likely if the house was poorly
framed), the entire trussed roof assembly or whole wall
sections blow out. "The house literally explodes," says Schiff.
"If it doesn't actually come apart, it's drenched by all the
wet air racing through the interior."
INSURANCE PRESSURES
During Hurricane Andrew, which meted out gusts up to 165 mph,
scenarios like this were common enough that damages mounted to
over $15 billion in insured losses. This made Andrew the
costliest natural disaster in insurance history, according to
the Insurance Information Institute. The hurricane destroyed
28,066 homes and damaged 107,380 others. While many of the
destroyed homes included house trailers that blew over for lack
of foundations, many permanent homes were torn apart by
wind-borne debris, and a majority of the damage was related to
openings that allowed wind-driven rain to soak interiors. "The
insurance pressure after Andrew, and to a lesser extent Hugo
which preceded it, has been tremendous. It's brought a new
emphasis on property damage in the building codes, not just on
human safety and loss of life," remarks Schiff.
In Andrew's wake, a majority of this attention has focused on
protecting house openings, including windows, entry doors,
sliding glass doors, garage doors, gable-end vents, and
skylights. Miami-Dade and Broward Counties were the first to
act, issuing impact-resistant safeguards as part of a revamped
1994 South Florida Building Code that also beefed up the
requirements for sheathing, nailing, rafter ties, and
sill-plate connections to help resist internal pressurization.
At the time, the impact-resistant measures amounted to
requiring hurricane shutters for all window and door openings
and reinforcement for garage doors. "Suddenly everyone's
selling 'hurricane shutters,' but there was no standard for
what type of shutter would effectively resist the impacts,"
added Schiff.
Winds whipped up by Hurricane Isabel came rushing in the
ocean-side windows and doors of this North Carolina home,
pressurizing the interior until the entire back wall blew off.
(Photo by Vince Lupo).
DEVELOPING IMPACT STANDARDS
It took another three years to develop a test standard for
evaluating windows and doors, as well. "The idea was to develop
an impact test that would simulate the effects of wind-borne
debris on any building product," explained David Hattis,
chairman of the committee of the American Standards for Testing
and Materials (ASTM) that is responsible for the development of
this new standard. Initiated by the Southern Building Code
Congress International, the development of the test was soon
handed over to ASTM when it became contentious. "The measure
was supported by academics and code officials, but opposed by
window manufacturers and homebuilders," Hattis said. "The ASTM
process is designed to achieve consensus."
The resulting test procedure, ASTM E1886, has two parts
— a large missile test that shoots a 2x4 from a
compressed-air cannon at a velocity of 50 feet per second (34
mph), and a small missile test that uses ball bearings
traveling at 80 feet per second (50 mph). After each impact,
the product, which is installed on a test wall or roof
assembly, must undergo 9,000 pressure cycles to simulate the
damaging pressure fluctuations of turbulent winds. These tests
work in concert with a companion standard, E1996, which
designates the wind zones where test-compliant products are
required and establishes pass/fail criteria for the tests. To
pass after impact and pressure cycling, the assembly cannot
have a hole large enough to fit a 3-inch sphere, or a tear
longer than 5 inches.
Under E1996, which was adopted into the 2000 International
Residential Code (IRC), "windborne debris" regions are defined
as follows: Hurricane-prone regions within one mile of the
coastal mean high-water line where the basic wind speed is 110
mph or greater; or anywhere the basic wind speed is 120 mph or
greater. By code, builders working within these zones are
required to install storm shutters or laminated-glass windows
and reinforced side-hinge doors and garage doors that can pass
the missile-impact and pressure-cycle tests. In states that
only recently adopted the IRC, the trick has been finding
suitable products. A couple years ago, only some aluminum
windows held an appropriate Miami-Dade County Notice of
Acceptance — the only certification available then
— but these single-pane units were not acceptable in
cooler climate regions where clients demand the comforts of
insulated glass. By this year, however, most of the top window
manufacturers have introduced a wide range of insulated and
non-insulated impact-resistant products, and manufacturers in
other product categories are catching up, though not without
difficulty.
"Initially, many coastal counties were shocked by the rules for
openings when the IRC was first adopted," said Dean Lewis,
certification manager for the American Architectural
Manufacturers Association (AAMA). "Many issued a moratorium
until there were products available that could meet the
standards." In March 2004, AAMA completed a certification
program for side-hinged entry doors that gives door
manufacturers a third-party certification of compliance with
the ASTM standards. According to Lewis, contractors and code
officials had little assurance prior to this program that
manufacturers were actually meeting the standards.
ONGOING REVISIONS
As recounted by Hattis, the ASTM impact standards have gone
through numerous revisions in a few short years and are likely
to undergo more. The first revision came after skylight
manufacturers argued that roof windows are not as likely to be
struck by heavy objects as windows lower on the building, and
that skylights make up a much smaller percentage of the
vulnerable surface area. The result was a new table in the
standard that lists lower impact requirements for skylights. A
second revision came from the effort to fold the Miami-Dade
county requirements into the ASTM standard. There has been
considerable discussion over whether the entire coastline
should be subject to the extreme conditions faced in Miami-Dade
County, says Hattis. A solution was found by adding a new zone
subject to winds in excess of 140 mph. The new wind zone
applies to Miami-Dade and Broward Counties, parts of the
Florida Keys, some sections of the Louisiana Delta, and the
southernmost tip of Texas. Shutter manufacturers brought
forward a third revision that sought clarification on how many
product specimens had to be tested. Shutters may come in
hundreds of different models, even though the basic
construction of models is similar.
The standard also has withstood numerous challenges by the
National Association of Home Builders (NAHB), which remains the
principal opponent to the measure. As an example, a 2001 report
by the NAHB Research Center argued that hurricane-force winds
at lower speeds are unlikely to launch 2x4-like projectiles,
and that in residential areas where gravel is seldom used as
roof ballast, ball bearings are not good representations of
actual windborne debris. ASTM's Hattis counters that although
it is true houses are more likely to be pelted by asphalt
shingles than 2x4s, any standardized test must be repeatable.
The test missile must be accurately aimed to hit the test
assembly in precise locations, such as at the intersection of
mullions or near the latch. Attempts to create accurate
missiles with asphalt shingles failed, reports Hattis.
Eventually the standards committee agreed to shorten the 2x4 to
simulate a lighter missile. "Reaching consensus on these
standards is always a political and commercial compromise,"
Hattis concluded. He also conceded that, going forward, it's
possible that the standards will evolve to include two
different criteria: one for windborne debris regions subject to
lower-speed winds, and one for higher. —
Clayton
DeKorneShifting Sands
Engineered beaches redefine U.S.
coastlines
Most U.S. beachgoers have never heard of the Ash Wednesday
storm, which pounded the New Jersey coast in the spring of
1962. But they can thank it for the sand beneath their feet.
The storm so eroded Jersey's booming beaches that the U.S. Army
Corps of Engineers initiated the feds' first big foray into
what has become a billion-dollar effort to continually
replenish beaches along U.S. coastlines.
Brevard County, Fla., with assistance from the Army Corps
of Engineers, renourished beaches in 2003 using sand leased by
the Department of the Interior's Minerals Management Service.
(Photo courtesy Marine Minerals Program, Minerals Management
Service)
EROSION MECHANISMS
Shaped by tides, currents, and storms, beaches erode, build up,
and shift. Over centuries, their nemesis is rising seas, says
Bob Dean, a recently retired University of Florida coastal
engineering professor. In the shorter term, the prevailing
northeastern winds angle waves and sand southward along the
entire East Coast. The process depletes some beaches and builds
up others, while inlets impede the flow. For example, Dean
blames the 19 Atlantic-side inlets in Florida — 16 of
them manmade or altered — for 80 to 85 percent of
erosion on the state's coastline. Structures such as jetties,
initially thought to stabilize beaches, had the opposite effect
and now are banned in some states.
As erosion worsened, the Corps' replenishment program
intensified. This year's 51 projects include 15 in
most-replenished Florida and 9 in runner-up New Jersey
— where virtually the entire coast is slated for
renourishment. Most projects occur along the heavily developed
New York to Miami shoreline, but the Corps also pumps sand onto
Gulf Coast, West Coast, and Great Lakes beaches. The annual
federal tab: over $100 million. State and local residents kick
in millions more through a cost-share arrangement established
in 1988, in which they provide 35 percent of the financing for
projects; the other 65 percent comes from federal money.
An offshore hopper dredge pumps excavated sand ashore where
bulldozers distribute the slurry for Brevard County's Shore
Protection Project.(Photos courtesy Marine Minerals
Program, Minerals Management Service)
TEMPORARY BENEFITS
The payoff for renourishment depends on your point of view.
Beaches absorb wave impacts. The wider the beach, the more
likely storm-driven waves will exhaust their energy. The Corps,
which agrees to renourish a beach only if reduction of
potential storm damage exceeds half the cost, says its main
goal is to protect communities. That's also the chief lightning
rod for critics, who say the consequence is that people build
where they shouldn't. "These areas are inherently risky," says
Kate Costenbader, a Corps-reform advocate with the National
Wildlife Federation.
Beach renourishment affords other advantages. "Nourishment
stimulates the hell out of development," observes Steve Benton,
coastal hazards coordinator for the N.C. Division of Coastal
Management. It also means more valuable real estate, which
prompts landowners and developers to build more expensive
structures, says Professor Dean, a renourishment
supporter.
Nevertheless, the growth-spurring mechanism is indirect. To
qualify for federal aid, beaches must already be developed. In
most states, renourishments aren't allowed to change
construction setbacks. Washington and South Carolina are the
exceptions, and South Carolina's policy has drawn only one
application, says Richard Chinnis, director of regulatory
programs at the S.C. Office of Ocean and Coastal Resource
Management. The more common avenue for setback relocations,
says Chinnis, continues to be the state's once-a-decade review
of coastal jurisdictional lines.
LONG-TERM DRAWBACKS
With typical renourishments lasting only 3 to 10 years, many
Corps projects are planned as 50-year efforts with multiple
return visits. No one claims renourishment is a permanent
solution. For this reason, critics say it's a waste of taxpayer
dollars that is made even less palatable by environmental
threats, ranging from the destruction of sea turtle nesting to
the muddying of fish habitat. "These are projects that are
intended to fail," Costenbader says. Supporters counter that
renourishments pump up tourism, property values, and local and
state economies, resulting in a net gain. Both the Clinton and
Bush administrations have rejected that argument, seeking to
reduce the federal contribution. Bush's proposed 2005 budget
would slash this year's fund of $106 million to $57 million,
eliminating more than 40 pending projects.
But supporters aren't worried. Lobbied intensely by the
American Shore & Beach Preservation Association (ASBPA)
and others, Congress has repeatedly exceeded presidential
requests. The 2004 budget, for example, is $21 million more
than Bush proposed. Says Harry Simmons, ASBPA president,
"[Legislators] in both parties and both houses are
overwhelmingly in support of putting it back in the budget."
— Aaron Hoover
Eye on the Sky
NOAA knows weather, so you can,
too
The night before scheduling a lumber delivery or opening up a
roof to tie in an addition, Mike Smith remembers how his father
sat hunched over a small transistor weather radio, trying to
decipher the staticky signals. "Most of the time, we were
listening to nautical reports miles offshore. It was impossible
to tell what would actually blow ashore or when," remembers
Smith, a second-generation Miami-based remodeler. "It wasn't
today's weather service, that's for sure."
These days,
Smith and other coastal contractors rely on the many online
weather-warning tools produced by the National Oceanic and
Atmospheric Administration (NOAA). "It's amazing how much you
can gather about the weather online," avows Smith.
Smith begins by monitoring the local pages of NOAA's National
Weather Service Forecast Office, keeping a link to Miami-South
Florida's point forecast map on his Web browser's toolbar, on
which he can click to get a general forecast of the week's
weather. (Similar maps are available for every locale in the
country from NOAA's Southern Region Headquarters' page at:
www.srh.weather.gov). As the summer storm
season approaches, Smith monitors the graphic watches, outlook,
and daily reports at NOAA's Storm Prediction Center
(www.spc.noaa.gov). These provide a quick
visual reference of any activity that might affect a given area
of the country. "If I see anything on the maps, I investigate
the discussions," Smith explains.
Discussions of all of the weather warnings consist of cryptic
text describing the exact nature of brewing storms. (For help
deciphering these messages, you may want to refer to NOAA's
list of acronyms at:
www.spc.noaa.gov/misc/acronyms.html)
Mostly, Smith says, he is looking for "SVR TSTMS" —
severe thunderstorms — common during the summer and
fall. According to Dan McCarthy, a warning coordination
meteorologist at the Storm Prediction Center, thunderstorms are
more dangerous than most people realize. "After tornadoes,
lightning is the number one weather killer," says McCarthy.
"Because lightning doesn't cause mass destruction like a
tornado or a hurricane, it gets far less attention than it
should." — Clayton DeKorne
Currents
RISING SEA LEVELS?
The Intergovernmental Panel on Climate Change has estimated
that the global average sea level has risen 4 to 10 inches in
the past century, and predicts that sea levels will rise 8 to
34 inches by the year 2100. While that won't cause an
inundation quite like that envisioned in "The Day After
Tomorrow," it will result in accelerated erosion. Along much of
the eastern seaboard and Gulf coasts, a 1-foot elevation in sea
level can result in 150 feet of landward erosion.
FASTENERS FOR TREATED WOOD
By now most builders know that the newer pressure-treated woods
— Alkaline Copper Quat (ACQ) and Copper Azole
— attack ordinary galvanized hardware. But what's the
alternative? Use only Type 304 or 316 stainless-steel fasteners
with the new treated woods along the ocean, advises the
Southern Pine Council.
SAFE HAVEN
In hurricane zones, the ultimate amenity may be a "safe room"
— a concrete shelter within a home built to withstand
winds up to 250 mph. FEMA's "Taking Shelter from the Storm"
provides complete instructions for building one. For more
information, contact FEMA at 888-565-3896;
www.fema.gov/mit/saferoom
